2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Can't Find Neutral... Me Neither
Old Yesterday, 08:18 PM
Weeboy1's Avatar
Weeboy1
Weeboy1 is offline
With properly adjusted clutch ensure primary fluid level is like diagram. Don’t get hung up on ounces get hung up on level. Mine calls for 38 I used about 35 last time. Also I switched to 75/140 gear oil in tranny and formula plus in primary. Considerable difference in neutral. Not like my sons Honda but vast improvement. Jmho
07UltraGuy (Yesterday)
Old Yesterday, 08:55 PM
npn's Avatar
npn
npn is offline
Originally Posted by 702
The Harley branded 80w-140 gear oil in the primary will work wonders for finding neutral.
So most people here and some on YouTube I've seen recommend Mobil 1 V-Twin Full Synthetic Motorcycle Oil 20W-50. That's what I use on my Sportster.
I'm confused - is the Mobile 1 gear oil or not?
Old Yesterday, 08:59 PM
gonemad's Avatar
gonemad
gonemad is offline
Received 7,400 Likes on 2,980 Posts
It’s motor oil, just like HD Syn 3 20w50 that HD will tell you to put in a trans or primary.
Old Yesterday, 09:23 PM
npn's Avatar
npn
npn is offline
Is this the right oil for the primary then? The one suggested by @702
Old Yesterday, 09:56 PM
Black Ultra's Avatar
Black Ultra
Black Ultra is offline
About 1 inch, maybe a bit more.
Almost an inch.
So initial to full engagement is the middle third of travel. Sounds about right. The advice about continuing to break it in seems prudent.
Old Yesterday, 10:03 PM
DK Custom's Avatar
DK Custom
DK Custom is online now
Platinum Sponsor
Received 4,244 Likes on 2,473 Posts
Make sure the primary does not have too much fluid in it.
Use Redline Shockproof in the transmission.
Way to know if the clutch is dragging is to have it in gear, engine off, on level ground...pull in the clutch lever. Does it roll as easily in gear as it does in neutral? If not, either clutch is out of adjustment, or there is too much oil in the primary.
Kevin
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
TwiZted Biker (Yesterday)
Old Yesterday, 10:28 PM
702's Avatar
702
702 is offline
Received 5,838 Likes on 2,389 Posts
Yes, that's the stuff I was talking about.
JONNIEROCK
05-25-2022 08:33 PM
Drnapalm
08-06-2019 05:37 PM
chestnut
04-02-2018 04:07 PM
B_CONA
10-08-2014 08:03 AM
P51Driver
10-19-2012 07:59 PM
Quick Reply: Can't Find Neutral... Me Neither
