Holding Clutch Basket to Tighten Nut
My 2015 St Glide Special clutch spins when I’m trying to tighten the main shaft nut. Even with the primary locking tool in place. I wonder if I can get away with two box wrenches around the place I’ve marked in the picture?
Edit: I just realized the bike was in neutral.
Glenn Gorman (07-08-2024)
Never thought about it before. My guess is that is the side of the clutch driven by the engine through the chain so it must be free to rotate on the transmission shaft at all times and the plates and spring is what connect to the transmission input shaft. The clutch hub nut is accessible to remove and install if the spring ring retaining the threaded center plate is removed and the plate is removed. No one has asked this question before so it must be that the clutch can be assembled off the bike and once installed, the locking tool can be used to tighten the six bolts to the proper torque. All of this is just a guess on my part as I have never had to disassemble a Harley clutch.
The following 2 users liked this post by Ya Tigor:
CoolBreeze3646 (07-10-2024),
djl (07-10-2024)
Just happen to have one but have only read the parts I needed for a particular operation. Will you make that same suggestion to the OP since he has taken his clutch apart?
Another tip could've read, "On hydraulic clutch equipped models, take care not to engage the clutch lever AT ANY TIME the clutch components are removed. This will prevent push-rod movement resulting in possible loss of pressure or vapor lock requiring additional bleeding of the system." Man, I am learning a ton with this DIY.
