2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Holding Clutch Basket to Tighten Nut
Old 07-10-2024, 05:06 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 9,497 Likes on 5,063 Posts
Originally Posted by stevepacman
It's too bad members feel the need to make snarky comments in forums. I don't get it. As for my situation, I DO have the factory service manual. Maybe I should've figured it out sooner, but a small note in the manual about ensuring the transmission wasn't in Neutral would've saved me a bunch of time.
People make snarky comments, yes, we all do sometimes.
Stop worrying about it and listen to people who know what they are talking about, they may have a little fun with you, but they are really trying to help.
If you follow the service manual, you will see that the hub nut is torqued or un torqued while the clutch is still assembled as a unit.
Forget about neutral, it makes not one bit of difference if the transmission is in gear or not.
Reassemble the clutch, then, using a locking bar, torque the hub nut, done.
Don't forget...The compensator, clutch, and primary chain are installed at the same time (it`s in the manual ).
Old 07-10-2024, 05:56 PM
stevepacman's Avatar
stevepacman
stevepacman is offline
The inner clutch basket would spin even with the locking bar in place. ...and I can read. I DID install the comp. sprocket and clutch at the same time - per the manual.
Old 07-10-2024, 08:54 PM
nutsandbolts5212's Avatar
nutsandbolts5212
nutsandbolts5212 is offline
Several people gave you solid advice. Any pictures of the work you're doing? That may help
Ride safe!
Old 07-11-2024, 06:08 AM
stevepacman
Ride safe!
I wound up upgrading to the Screamin Eagle Assist & Slip Clutch Kit. Super-easy installation.
Old 07-11-2024, 10:57 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Of course the clutch hub spins, the clutch was missing the plates and disks, you have already been told that.
I never said you can`t read.
Here`s a tip: when you are looking for help, don`t be a dick when you respond to the people who are taking time out of their day trying to help you.
Ohio HD (07-11-2024)
Old 07-11-2024, 12:04 PM
stevepacman
Hahaha!
miky2001
09-21-2022 11:04 AM
thanoskazakos
06-22-2018 05:53 PM
Pipeliner
03-23-2016 06:02 PM
kountry
06-05-2015 10:00 PM
Quick Reply: Holding Clutch Basket to Tighten Nut
