Need Advise Please-Used Road King Purchase
The following 4 users liked this post by hoggy05:
Rob Harper (07-08-2024)
I would be partial to a Rushmore 103. I love my '09 103, I've heard bad things about the water pump & then sumping issues with the M8s. But then again plenty have tens of thousands of miles w/o issue. So I suppose it's the luck of the draw. I have absolutely nothing against the M8s & actually really enjoyed the '17 UC that I rented. However I think the twin cam has more character & still like the twin cam 'shake'.
That about sums it up.
If you end up with an M8, I doubt you'd be wishing you had a Twin Cam.
If you end up with a Twin Cam, you might wish you had an M8.
Regarding the previously mentioned oil pump situation in earlier M8's...
Chances are, that if the bike suffered from a sumping issue, it would have been dealt with by now.
Potential seller should be able to provide documentation.
I elected to switch to an S&S oil pump on my 2018 Road King (good enough excuse to swap cams etc. as well).
For what it's worth, I am very pleased with my M8 R.K.
Best of luck to you!
The following 2 users liked this post by already in use:
Goose_NC (07-10-2024),
MRFREEZE57 (07-06-2024)
1 - The piston oilers were not seated correctly from the factory, and/or the piston oilers did not work correctly from the factory. Not an easy fix as the motor has to be taken apart, but it can be fixed.
2 - Where the case is bored and the sump plug is installed, the bore is not consistent. The length of the sump plug covers/interferes with oil flow. Easy fix, replace the sump plug with a Fueling short sump plug.
I’ve owned every year of the M8, except 2024. Most of them had performance work done to the motor. From a HD stage 2, to HD 131 to a FM 128. Thousands of miles out on each bike and none of them have had sumping issues. I’ve only replaced the oil pump on one bike. That was my ‘21 FLHTK with a HD 131 and aftermarket cam.
Good luck in your search for a Road King!
bradsULtd (07-06-2024)
