2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Whats up with the m8's not just the 107?
Old 05-02-2024, 10:00 AM
r0de_runr's Avatar
r0de_runr
r0de_runr is offline
Originally Posted by Tours
Yes the brake light was addressed by the dealer before I bought the bike, however thank you for the heads up but my question still remains because the warranty ran out in February 2024 I turn down the extended warranty before I read all the issues they are having with the Harley m8's
If you would have had problems, you'd know it by now. It's not an issue that pops up later, it shows itself right away...continuous high rpm >3500k will manifest it. You either have it or you don't.
Not every M8 experienced sumping.
My 2019 114 is an original oil pump design and no sumping in over 40k miles.
So, if it is something you worry about top the point of not enjoying your bike, then just have the oil pump replaced now, less cost that ESP. And I'm not sure the ESP will cover sumping as it is very difficult to diagnose and repeat (unless your engine grenades).
My 2019 Limited 114 and my 2022 Softail Heritage 114 are both flawless in that I have no sumping, no oil in air cleaner, and once the kit was installed on the 2019, no trans fluid migration to primary.
  #42
Old 05-02-2024, 10:03 AM
Notgrownup's Avatar
Notgrownup
Notgrownup is offline
Received 7,106 Likes on 3,650 Posts
If you really want a ESP get one that is aftermarket like from Jim Palmer
The following 2 users liked this post by Notgrownup:
BrandonSmith (05-02-2024), rigidthumper (05-02-2024)
  #43
Old 05-02-2024, 10:12 AM
r0de_runr's Avatar
r0de_runr
You can visually check if you have the latest oil pump by removing the cam cover and looking for the tab on the oil pump.
Also here is an image of what to look for. You just need to remove the cam cover (probably and the exhaust) to get a look at the oil pump.
https://static.nhtsa.gov/odi/tsbs/20...64800-9999.pdf
VortecCPI (05-02-2024)
  #44
Old 05-02-2024, 12:41 PM
VortecCPI's Avatar
VortecCPI
VortecCPI is offline
Originally Posted by BrandonSmith
How about this: my 2017 M8 107 is running fine in the Southern heat after 42,000 miles. Oh, but I did have both head gaskets fail around 20,000 miles. Other than that, all is good.
What was the cause of the head gasket failure?
  #45
Old 05-02-2024, 12:50 PM
BrandonSmith's Avatar
BrandonSmith
BrandonSmith is offline
Received 3,131 Likes on 1,846 Posts
Your guess is as good as mine. They seem to fail on the exhaust side.
This is not my picture (credit: Havinabubble), but both mine looked the same - as did several others on this forum (LINK).
Or here:
  #46
Old 05-02-2024, 01:11 PM
VortecCPI's Avatar
VortecCPI
Hopefully the newer high-compression 121s will not have head gasket issues...
  #47
Old 05-02-2024, 02:40 PM
BrandonSmith
I think it was mostly the early M8 engines, prior to 2019-ish. I don't think there were any changes in the part number for the gasket, but I don't see anyone complaining anymore.
  #48
Old 05-02-2024, 09:27 PM
rigidthumper's Avatar
rigidthumper
rigidthumper is offline
Veteran: ArmyVeteran: Navy
Received 6,502 Likes on 1,799 Posts
My 2019 trike (build date 11/18) did that, at about 5200 miles. Switched to Cometic gaskets, I believe it's cured.
wztravis
2018+ Softail Models
18
08-20-2023 12:41 PM
jdmac
Panhead
11-09-2020 07:29 PM
Mattbastard
Milwaukee Eight (M8)
57
03-05-2020 11:26 PM
martinbastin
12-26-2010 02:01 PM
Quick Reply: Whats up with the m8's not just the 107?
