2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Can’t Get Past 4th Digit of Pin
Old 10-30-2023 | 06:16 AM
oo10inz's Avatar
oo10inz
Originally Posted by snipit
Have you tried the default code that comes with the bike when new? I think it's 31313.
I have indeed, that was one of the more recent things i he tried once discovering that default number. I am really at a loss on this one especially with having it work flawlessly before.
Old 10-30-2023 | 06:17 AM
oo10inz's Avatar
oo10inz
Originally Posted by Bayou FLHR-M8-128"
I have been waiting for the answer as this is EXACTLY what my 2019 RK is doing and this is my 3rd Harley with this. 🤦‍♂️🤷‍♂️
Were your 3 all stock or did they have any work done to them?
havinabubble's Avatar
havinabubble
in my experience there isn't a default, the dealers seem to change them accordingly
have you tried changing it to something new and trying that number?
The following 2 users liked this post by havinabubble:
Goose_NC (10-30-2023), Rogue1 (12-31-2023)
Old 10-30-2023 | 06:21 AM
oo10inz's Avatar
oo10inz
Originally Posted by havinabubble
sorry if this is sucking eggs
A PIN is a five-digit number (1-9, no zeros).
I take it you have 'revealed' your current code by having the fob present and doing the reveal rain-dance?
...and aren't just guessing what you think the code to be
from the user manual:
Correct am able to do the process and have confirmed that the correct code is the one i have changed it too. I have also changed it to a few different ones hoping that would kind of snap it out if it and so far no luck in that as well
havinabubble (10-30-2023)
Old 10-30-2023 | 06:23 AM
havinabubble
random thought....
fob present, turn bike to ON
pull the master fuse
give it a few mins
put fuse back in and turn bike OFF
...try pin dance again
Old 10-30-2023 | 06:36 AM
oo10inz's Avatar
oo10inz
random thought....
give it a few mins
When you say on do you mean ignition or run switch? forgive me if this is a stupid question but will it reset the tune i had done? or the audio upgrade and tuning i had installed as well?
Old 10-30-2023 | 06:43 AM
havinabubble
sorry not sure what bike we are dealing with?
on my 2017 FLHXS: large headstock ignition switch turns the power on and off to the bike. Engine off/RUN switch turns the motor off and on
You need to unarm the security by turning the power ON
then yank the fuse
otherwise the security system is armed...by turning the power on it thinks its off and you then kill the power with the fuse being removed
...shouldn't effect either the tune or the radio
Old 10-30-2023 | 06:51 AM
oo10inz's Avatar
oo10inz
then yank the fuse
My apologies it is a 2021 Street Glide Special.
Old 10-30-2023 | 06:53 AM
havinabubble
cool, same then
with fob present
rotate the switch to IGNITION (the dash lights up)
Old 12-31-2023 | 08:16 AM
Gmorris1911's Avatar
Gmorris1911
Stage I
Default Checking In
what’s up guys. Just like the title says i can’t get past the 4th digit of my pin when starting my bike without the fob. i’ve tried changing it, accessing it everything else with the pin process works except when i try to use it. I’ve used it before without issues however now the 4th digit even when right stops process and engages the security system. anyone else experience this? not really sure where to go from here. Thanks all!
I was reading up on this post because I am having the same issue. I didn't see a fix to this and wondered if you ever found a solution to this problem.
Bayou FLHR-M8-128" (12-31-2023)
Quick Reply: Can’t Get Past 4th Digit of Pin
