Failed S&S M8 oil pump
Why do you want to change the pump and cam plate on a new '23 model? The '23 cam plate from H-D is a new part and the oil pump has been recently updated as well.
It's a sensitive balance to achieve proper oil scavenging and oil supply in an H-D engine as evidenced by the oil transfer and breather issues that H-D spent years fine tuning to where it is now.
The following 5 users liked this post by Hulkss:
00 fxd (03-08-2023),
bson (03-09-2023),
VortecCPI (03-08-2023),
wilburbill (03-08-2023),
wmprof (03-08-2023)
new 2023 Road Glide Limited. 865 miles. No issues, no known blow by, no sumping. I just want to do what I can to improve oil flow. Other than the S&S cam plate and oil pump going in, I may add a torque cam, tuner and better lifters. I don’t want to have to change the exhaust just yet.
Firsthand experience; we've installed & sold an extensive amount of S&S M8 oil pumps & cam plates and I have seen zero failures. I've seen motors go down and destroy and oil pump/plate however that was the secondary effect not the root cause.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
According to Kevin Baxter at ProTwin, he likes to see pinion shaft runout <3 thousandths but 5-6 thousands is ok. Excessive pinion shaft runout will wear out any cam plate regardless of who the manufacturer is. We’re first checking runout before anything gets changed. This will give me a baseline.
