The 2023 Road King FLHR Lives On As The FLHP
#681
Hulk, this situation has been bothering me since you posted it.
Since day 1 on my 2023 I felt that my belt was way too tight.
Asked at the dealership - of course they blew me off on the subject.
I sort of hoped that it may seat a bit and have a bit more reasonable feel but I'm up to 7500 miles and it's still the same.
With your accelerated pulley wear I wonder if you have any thoughts on this?
Also did you discuss a warranty replacement? You should still be within the two years basic warranty.
#682
I set the belt tension with the bike on a frame lift stand with the rear wheel off the ground. I set it close to 9/16 loose in the belt guard window using the H-D tension tool.
#683
I hear ya Hulkss. I was going to mod my existing cover, but this cvo cover is certainly better. I think I will install this new cover (ordered today) and pull the rubber tubes in the throttle body and observe. And yes the stock rubber hose and fitting are very small. As long as the crankcase pathway is the same, I can't see why there would be an issue tapping off the head breather holes.
#684
#685
The following 2 users liked this post by Hulkss:
18PiecesofFlair (04-20-2024),
bpav16 (04-18-2024)
#686
Took her for a 1500 mile shakedown run, I think she going to work out fine. I have a few doo-dads and slip-ons with 2” baffles. On the shelf is a new headpipe, ventilator a/c, proper cable for power vision unit, license is needed. I’m sure a proper tune would help.
Planning to take an extended ride soon
#687
Bhrees (04-25-2024)
#688
I looked at a new '24 Road Glide Police model yesterday, Impact Blue. I'm passing on it, but maybe somebody here might be interested. Listed at $21,199, at Arrowhead H-D in Peoria, AZ, and available for purchase immediately. Friend of mine had ordered it, but then switched over to a new '24 Road Glide when they were released.
**If anybody knows of a new '24 FLHP (or a '23 as well) available now - at a reasonable price - let me know. A couple of you mentioned dealers with one or two, but they all were asking well over $26K; I'm just not willing to pay that much for one. Even a newer used one would work for me as well.
#689
2023 & 2024 new FLHPs
00 fxd (04-22-2024)
#690
