Fork Bracket Pinch Screws
Doing some front end work and had to remove my factory fork bracket pinch screws and realized they were pretty rusty. The SM specifically calls for blue thread locker on the fork slider cover screws, but doesn't mention anything for the fork bracket pinch screws. Is it okay to use blue on these also?
Pretty rusty meaning the screws had surface rust all over the threads, but nothing structurally compromising. I am replacing them regardless with ARP fasteners. The whole reason I brought up the use of Loctite is because it prevents rust & corrosion.
NCPiper (03-14-2022)
If the service manual doesn't call for it, it's most likely not needed.... but blue threadlocker won't hurt anything...
When I switched to stainless bolts on my engine cases, the bolt kit company called for blue threadlocker or anti-seize to avoid galvanic corrosion... I used blue threadlocker, but I am diligent about chasing/cleaning the bolts and bolt holes if I ever remove the fasteners, before reassembly...
The following 2 users liked this post by hattitude:
NCPiper (03-14-2022),
twincam10353 (03-14-2022)
I'm the same way except I don't do much "thread chasing" anymore. If I know all I'm doing is cleaning out old dried up Loctite, I run a stainless bore brush through the female threads with a cordless drill. It's just so much faster and easier.
I wish I could just brush out the bolt holes... the older I get, the more picky I get...
In my youth, I would just blow away any visible debris with my breath or wipe it with my hand...
Then I graduated to clearing bolt holes with compressed air...
Then I started using thread chasers on bolts and bolt holes.. AND still blowing out the holes with compressed air...
For the last several years I find myself using thread chasers on bolts and bolts, THEN running the bolts on my bench mounted wire wheel, AND blowing out the holes with compressed air...
Sure hope I don't add another step to my OCD.......
