2016 Road glide special blinker/ brake light problem
Good afternoon guys i have a problem with the lighting on the rear of my road glide!
the running lights work every time without fail
with the bike turned OFF the blinker and brake light and tail light all work as they should * note the front blinker blinks at normal rate
With the bike running the REAR blinker and brake light dont work but the tail light does *note the front blinker hyperflashes like it doesnt see the rear connected odd bc the Tail light works lol
I recently put handlebars on with no issues for a couple weeks till now
i would think thats my problem but the circumstance of working with the bike off and not with it running all seems odd
any idea of what is causing this would be awesome
Thanks in advance
Thanks in advance
could be a pinched wire somewhere. A similar thing happened to my buddy's bike. Everything worked fine for a little while after he put on his new bars, then eventually a couple pinched wires wore through and started shorting out. I'd double check your wiring around your bars. You may find a pinched spot
the left side works perfectly blinker and brake light and tail light all the time running or not but the right side only works fully when the bike is off
bonecross9 (03-27-2020)
I believe i have fixed the code b2156 right rear turn signal overload problem
I rode the bike for an hour or so after replacing the bulb and everything worked as it should
I even checked the resistance of the old bulbs and they tested similar to each other(both old bulbs)
odd i only had a code for the right side
Thank you for all the responses part of the reason i love riding is the community that comes with it!
Thanks again
Thanks again
