2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Handlebar Thread - Apes no higher than fairing
Old 08-12-2019, 08:21 PM
mcouture's Avatar
mcouture
mcouture is offline
Default Handlebar Thread - Apes no higher than fairing
I'm starting my search for some taller bars for my 2015 Limited Low.
I'm tired of the really low stock bars. If I put my hands up onto the tops of the mirrors, it seems to be the perfect height.... The stock low bars have a pullback of 13" and I can deal with about 9-12" give or take. I think I want a bar with less bend or angle to the handlebars. I don't want to go above the fairing.
Talking with LA Choppers they have a new bar called Grande Twin Peaks that have a 10" pullback and wrist angle is 33 degrees...
The width might be an issue since they are 36.5" wide...that's 3" wider than the stock low bars...
https://www.denniskirk.com/la-choppe...rd/5903139.sku
Anybody put their hands on these bars yet?
Any other options for what I am looking for?
Old 08-12-2019, 08:39 PM
lp's Avatar
lp
lp is offline
Received 2,834 Likes on 1,595 Posts
I've heard good things about the Wild1 WO578s. A 10 Inch mini ape with good bends and sits just under the fairing.
Old 08-12-2019, 09:00 PM
Blowby's Avatar
Blowby
Blowby is offline
That’s what I’m running on my 2003.
Old 08-12-2019, 09:02 PM
Cosmic Razorback's Avatar
Cosmic Razorback
Cosmic Razorback is offline
Received 18,043 Likes on 7,312 Posts
Wild One WO578
Yaffe 10 inch Monkey bars
I have ran both above. The Wild Ones are extremely comfortable. They are wide however. The Yaffe’s look great.
For me I am 6’1” tall and Yaffe 12 inch are most comfortable for me. However they are just above the fairing. See picture in signature.
Good luck
The following 2 users liked this post by Cosmic Razorback:
lyork (11-26-2019), ringer1969 (08-13-2019)
Old 08-12-2019, 09:40 PM
Randy Oblong's Avatar
Randy Oblong
Randy Oblong is offline
LA Choppers Twin Peaks 10". Bad angle but right at top of fairing. Not too wide.
Old 08-12-2019, 09:53 PM
langwilliams's Avatar
langwilliams
langwilliams is offline
I run the wild 1 WO579 bars an they put my hands right in front of the mirrors so I had to add mirrors to the bars. They are 1.25" so the inner fairing doesn't clear an you have to tweak an trim to clear them. I wish I could stand them up more but the slots in the inner fairing are for 1" bars. I like the peak bars too but was afraid of problems running wires in them. It's a pain in the @$$ adjusting the bars since you have to snug them an position the fairing if in the right position tilt the fairing forward again to tighten the risers then position the fairing again.....I was thinking about trying to head the inner fairing up some with a heat gun with the bars loosely mounted an pushing them forward into the bar slots to get them more upright.
JonW's Avatar
JonW
JonW is offline
I'm very happy with the Straight Jacket bar I got from KST. It's a 12" bar and the pullback is not too severe.
Attachment 616415
Attachment 618013
Old 08-12-2019, 09:56 PM
langwilliams
here's a pic but it's not a close up of the bar position
Old 08-13-2019, 05:05 AM
lp's Avatar
lp
lp is offline
Looks like you could have used the WO578s. They are more upright.
Old 08-13-2019, 06:44 AM
BlkDragon's Avatar
BlkDragon
BlkDragon is offline
10" will do the trick.....12" is a little higher than the fairing...….I can only speak for Street Glide.
Quick Reply: Handlebar Thread - Apes no higher than fairing
