2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Gas treatment.
Old 07-26-2019, 11:17 AM
gosserwb's Avatar
gosserwb
gosserwb is offline
Default Gas treatment.
Anybody use fuel injector cleaner in their bikes. Is it a good idea to use somthing or will it harm anything. In going on a trip around lake superior thinking of putting some in.
Old 07-26-2019, 11:29 AM
chopper_man's Avatar
chopper_man
chopper_man is offline
Received 1,665 Likes on 990 Posts
If your bike is running good you should never do anything before a trip, simply not a good idea. If you are running quality gas and are not having issues then it's really unneeded IMHO.
Old 07-26-2019, 12:55 PM
GalvTexGuy's Avatar
GalvTexGuy
GalvTexGuy is online now
Received 4,241 Likes on 2,322 Posts
Use top tier fuel. It's "supposed" to contain additives that keep fuel injectors clean.
The following 3 users liked this post by GalvTexGuy:
Ddieselsmoke (07-28-2019), leftyjm (09-27-2019), Wildon883R (07-30-2019)
Old 07-26-2019, 01:49 PM
gosserwb's Avatar
gosserwb
gosserwb is offline
I allways use premium gas however most gas stations have 10% ethanol. That's why I was adking
Old 07-26-2019, 02:46 PM
IUOE ROB's Avatar
IUOE ROB
IUOE ROB is offline
I use Techron in my Vette, usually a container every oil change. Every so often I'll throw some in the bike, no set schedule just every once in awhile and never had any issues...
Old 07-26-2019, 03:34 PM
steelerdude1's Avatar
steelerdude1
steelerdude1 is offline
I use sea foam for winter storage, and it is said to have cleaning agents as well. So when I burn off my first tank of fuel of the year, it gets a “treatment”.
That being said, I agree with the above post to not try anything new before a trip.
Old 07-26-2019, 04:55 PM
470004's Avatar
470004
470004 is offline
Received 16,343 Likes on 6,765 Posts
I do not use any additives, except for winter storage.
Old 07-26-2019, 05:13 PM
Stinger1's Avatar
Stinger1
Stinger1 is offline
You mean like change fluids, check tire pressures, check bolts and nuts, fix any oil leaks,check lights, check brake pads and hoses, check drive belt, check battery voltage, check wheel bearings.
Is this what you mean? Your nuts. There are tons of things to do and check before a trip.
Old 07-27-2019, 08:46 AM
chopper_man
No, you should not change fluids right before a trip, but you should absolutely check them prior tho. If you are due for a change prior to the trip you should do them several weeks before hand and get miles under you before the trip. The rest of your list is checks, all of which should be done, the majority of which are part of your routine maintenance.
Old 07-27-2019, 10:06 PM
Hammz's Avatar
Hammz
Hammz is offline
Quick Reply: Gas treatment.
