2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Anyone Have a Madstad on Their Ultra Limited?
Old 06-13-2019, 07:00 AM
Robb Liupo's Avatar
Robb Liupo
Robb Liupo is offline
Just my two cents, I have used Klocks Works windshields on three bikes and love them. I have a couple of different heights that I switch depending upon the temp and weather. I do feel the bike, a 2010 Ultra, rides better than with the stock shield. I also like the fact that they are a small family owned company from South Dakota. Harley copied their design a couple of years ago so they can't be all bad.
Old 06-14-2019, 09:09 AM
VA_Larry's Avatar
VA_Larry
VA_Larry is online now
Originally Posted by DaveNBPT
Would love to see pictures of your Madstad. I too, have the fangs and triple tree wind deflector. I assume an easy install?
dceggert (06-14-2019)
Old 06-14-2019, 10:55 AM
so60's Avatar
so60
so60 is offline
Default Question for VA_LARRY
VA_LARRY, a couple of questions for you. What size is your Madstad, the 9, 11, or 13 inch version (looks like maybe the 11) and which tint if any. Is the install just basically removing your old shield, installing the new dark "base" screen to the fairing, and then mounting the brackets and shield on the base?
Also, I would like to see another pick of the inside fairing area with a little wider view. I am kinda interested in all the stuff you seem to have mounted in there, what it is and the type mounts. Thanks.
Old 06-15-2019, 06:12 AM
DaveNBPT's Avatar
DaveNBPT
DaveNBPT is offline
Originally Posted by VA_Larry
Thank you VA_Larry! Nice set-up you got there. What is your camera mounted to? On my last Limited, I used the Ram mirror mount and I liked that. I'll likely do that again.
Old 06-28-2019, 07:09 PM
DaveNBPT's Avatar
DaveNBPT
DaveNBPT is offline
Installed my Madstad today and took it for a couple of spins...adjustied to different heights, half helmet, then modular. Definitely good wind protection. Could set the windshield height so that the wind would blow over the top of my helmet. It'll take some time to get used to the solid/opaque base plate. It's like having a shorty shield that you can't see through. I had purchased a Freedom Touring shield prior to the Madstad, but I was still getting whacked on the top of my helmet. I am going to try a couple of different sizes up with the Freedom to see how they fare. I'll likely keep a Freedom Touring shield and the Madstad. The only "shortcoming" I can think of with the Madstad is the windflow on/over the sides of the faring...not terrible, but noticible, especially after using the Freedom Touring shield, which seemed to give good protection to the arms/shoulders. And yes, the Madstad is ugly!
Old 02-08-2020, 06:51 AM
PukinDogs's Avatar
PukinDogs
PukinDogs is offline
6th Gear
DaveNBPT, can we get a update on your Madstad experience? Thx
Old 02-08-2020, 01:15 PM
nobodyknowsme's Avatar
nobodyknowsme
nobodyknowsme is offline
Received 14,667 Likes on 6,425 Posts
He hasn't posted since October of last year.
Old 02-08-2020, 02:42 PM
jonuphi's Avatar
jonuphi
jonuphi is offline
9' light tint on my Reckless fairing
Old 02-08-2020, 03:34 PM
biglew55's Avatar
biglew55
biglew55 is offline
Default 2018 w Madstad
Ran this on my 2018 for 2 years and about 40000 miles. Used it for my UCC in 18 and the IBR in 19.
I ordered mine 2 inches taller to mount things on. Would recommend only going +1 not +2 though. Only negative l can think of is some extra wind noise. I wear earplugs so it's a non issue for me but it could be annoying otherwise.
Other than that, it's awesome. Gives a much better wind pocket to ride in, especially in crosswinds.
Edit....wind noise is from the fairing area not from wind on or around the helmet
PukinDogs (02-09-2020)
Old 02-09-2020, 01:29 PM
Cosmic Razorback's Avatar
Cosmic Razorback
Cosmic Razorback is online now
Received 18,028 Likes on 7,307 Posts
Interesting product. I have not seen these before. It is a lot of stuff to have to look over / throughfor sure.
Quick Reply: Anyone Have a Madstad on Their Ultra Limited?
