Lowering just the rear
05-29-2019 | 08:10 PM
Quote:
Originally Posted by
BrandonSmith
Correct. All touring models have identical front fork setup.
Not quite true... The FLHTKL is 1" lower in the front.....
05-29-2019 | 08:16 PM
05-30-2019 | 07:46 AM
i was certain on the "low" models having lower front end....wasn't sure on the others.....thanks guys!!!!
05-30-2019 | 08:27 AM
Toe Knee
Anyone go from 13" to 12" in the rear on their 14' or later touring bike with out changing the front?
if so, got a pic and did you have any handling issues?
Thanks,
Tony
Have done it to 3 street Glides. No problem.
05-30-2019 | 05:09 PM
I lowered my 17 FLHTK 1 inch with lowering kit. No problems so far
05-31-2019 | 08:30 AM
I put Progressive 944s in about a year after getting my first bagger. I'll probably never ride a 13" shock again. When my foot drags over the seat getting off frequently enough, the seam of the seat rips out.
Now that it sits at 12" that doesn't happen.
Six months later I put the 1" lower front end in from Progressive and I like this ride even more.
05-31-2019 | 09:45 PM
Srodden
Keep your 13" shocks for the extra inch of travel and use these blocks. You can get them from D&K, a forum sponsor.
06-01-2019 | 12:47 AM
Get a set of take off 12"
if you have a 14 or newer and use the lowering blocks check your bag clearance mine rubbed the paint off the inside of the bag. I then bought a set of 12" take off from a Street Glide Ride even better then the lowering blocks. Much happier
06-01-2019 | 04:30 PM
You can also lower it a little by installing a smaller tire, i.e. 185/60/16 or 185/55/16.
06-01-2019 | 05:18 PM
‘16 FLHTK - I went from 13” HD air shocks, to 11” Pro Action coil overs. No issues. Plus a street glide seat that lowers me even more!
