New switch in Dash Panel
I am installing the Cool flow fan. So far, it has been a nightmare. The instructions are absolutely awful.
I am installing the fan switch in the left dash panel. I removed the ignition lock and the switch console. I searched the service manual for guidance but found none. I pulled the dummy switch out of the right-most socket. I could not find a release mechanism so I just used brute force and pulled the dummy one out.
Now I insert the new switch provided but it does not "lock" into place. I am able to insearch it all the way into the socket but I can simply pluck it back out!!! That can't be right.
What is supposed to keep the switch in place?
Dash panel with new switch on left.
See the little silver tab below the fan switch? Pull that out.... it doesn't come out completely but it is that allows the switch cap to be replaced.
The install is actually very easy. Once you have done it. The instructions are horrible. PM me if you have further questions. I got mine installed in about 30 minutes then coded at the dealer for $25
If it gets ugly I can pass you my cell and you can call, I can then explain it easily enough...
GL
GL
SpringerRider (05-11-2019)
I have it all wired and closed up. I will take the Trike to HD to get the head flashed.
Should I be able to start the fan now? I started the bike and pressed the switch several times with my hand over the fan outlet but nothing comes on. As I stated above, without any real wire markings, I just fitted the wiring to the available unused sockets that I found and laced the fan harness into it.
Here are the instructions that are currently on HD's website:
https://serviceinfo.harley-davidson....7?locale=en_US
You have to get it activated at the dealer for "auto" mode.
On a 2017 and up not sure if you have to get it activated for just on/off.
In the instructions it reads:
"Installation of this kit requires programming with Digital Technician II to enable the fan. See a Harley-Davidson dealer."
So there ya go, needs to be activated.
On my 2015 it worked out of the box but 2016 and under there is no "auto" mode available.
FYI the tabs in the circles below are the release tabs.
SpringerRider (05-13-2019)
If you place it ON you will hear that damn thing when you stop with the engine off, it is quite loud. I leave mine on Auto.
Auto turns it on under 35 MPH I think it is and shuts it down when you break 40 again.
The right switch position in the left console switchpack provides a canbus signal to the BCM to energize (supply 12VDC) to the ACCY circuit harness. That output is through the ACCY Relay, which allows high current draw devices to be switched from the console. The center switch position signals the BCM to turn on/off the lower power leads on the ACCY harness (when installed). My '14 version of the fan is manual only; no "auto" mode but no programming needed to make it work.
hbsoldier3 (05-13-2019)
