what's up with my music?
So, I have 60 or so songs loaded onto a "shockproof" 10gig usb stick. Every so often a song skips like if you were to bump an old cd player, sometimes it cuts to the FM radio and then back to the song on my flash drive. Has anyone else experienced this? I don't think its a connection issue as it reoccurs at the same spot in certain songs (like if there were a scratch on the track). Any insight would be greatly appreciated. !!
I usually stream bluetooth from my phone and still have problems similar to this. Sometimes it happens when I skip a song, doesn’t matter if its with iTunes, Pandora, Spotify or iHeart Radio, the radio will just kick back to FM. Just about every time I switch from one of those to another it also kicks back to FM. It’s like the com connection gets broken.
Not sure if you are plugging the USB stick directly in to the bike or with a usb cord between, either way it could be as simple as that connection. Make sure they are connected well. Another thought is clean the metal part of the USB stick that plugs in with a alcohol pad then use some of that canned air made for cleaning computers to shot a burst into the USB port on the bike. If you have a little fuzz, trash or dust in the USB connections it could give you those symptoms as well
I use a 32gb stick with no issues. I am only using 17.2gb of it. It has 2134 songs which gives me 6 days of music.
The songs are stored in 206 folders and accessed with 83 playlists.
Once the entire stick has been read into the boom box it should stop "reading". If you modify the stick or put in
a different one then it will go into "reading" again.
