2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Loud Electric Horns, No Air Please
Old 05-08-2019, 07:54 AM
16FXDLI's Avatar
16FXDLI
16FXDLI is offline
My 16 SGS has the loudest motorcycle horn I’ve ever heard. As previously mentioned, it’s louder than my car horns. Shockingly loud. Go to a dealer and try the horn on one of their used Rushmore bikes.
Old 05-19-2019, 12:19 PM
nycruiserman's Avatar
nycruiserman
nycruiserman is offline
Recently switched out the horn for the Drag Specialties 2107-0156 on my 16 Ultra Limited Low. Happy with the ease of installation and the sound out of it. Very loud! Pitch is a little higher than I expected but it cuts clear across the neighborhood. Wife heard it from 3 blocks over in normal daily traffic noise (disclaimer: of course, she was listening for it). Been on for about a week, will repost if anything changes to make my unhappy.
Long lonesome highwayman (05-19-2019)
Old 05-19-2019, 01:26 PM
RANGER73's Avatar
RANGER73
RANGER73 is offline
Received 6,339 Likes on 3,186 Posts
I've got a mini beast sitting on the shelf. Only reason I removed it was that I changed up the look. It's the black ribbed oval one. Before the changed to plastic.
Old 05-19-2019, 01:59 PM
Long lonesome highwayman's Avatar
Long lonesome highwayman is offline
Received 7,429 Likes on 2,845 Posts
That to hear the positive report. I think that's the same one I just bought for my Sporty. I haven't had a chance to install it yet, but will do it before I ride it again.
nycruiserman (05-20-2019)
Old 05-19-2019, 04:54 PM
XTonerman's Avatar
XTonerman
XTonerman is offline
Default Horns
Greetings
I purchased the low note freeway blaster but haven't installed yet. I do like the idea of using the space under the right side cover and mount there. I do love the clean look. I am still interested in ideas.
Old 05-20-2019, 05:59 PM
VA_Larry's Avatar
VA_Larry
VA_Larry is offline
PM if you're interested in selling it.
Old 06-04-2019, 09:04 PM
I finally got a chance to install the Drag Specialties electric horn on my 98 Sportster. It was listed as 110 db but it's not and I didn't believe that anyway, More like 86 db. To realistically get to 110 you're probably going to have to go with an air horn, with an added relay. It was however inexpensive and very easy to install. Not exactly the same as if I was installing a stock horn, but close enough that I didn't have to do any major work to get in installed. Wiring was simply unclip the 2 stock wires from the the tabs at the back of the old horn, reattach to new horn in the same manner. In my case the black wire was at the rear of the bike. Total time was probably a leisurely ten minutes. At least I can easily hear it over my exhaust pipes going down the road, which I barely could with my shameful pathetic stock horn.
Old 06-04-2019, 09:14 PM
Originally Posted by Wildon883R
My 15 RGS stock horn is as loud if not louder than any car or truck on the road. Its louder than both our cages and way over 100db
If you've got a stock Harley horn that is over 100 db I'd like to know what it is so I can get it too. iI've read somewhere the stock pre 13 horns were 80 db. Although a 5 db increase doesn't sound like much, it's actually more significant than it sounds.
From this link:
https://www.harley-davidson.com/stor...mount-horn-kit
Get Noticed! Ride with increased confidence with a loud horn that will grab everyone's attention.
  • Engineered to be 5 dB louder (at 2 meters) than the '13-earlier Original Equipment side-mounted horn.
  • Designed to be a plug-in replacement that is easy to install
  • Horn is stock on '14-later models equipped with side-mount horn covers
  • Fits with all H-D® side mount horn covers
Old 06-05-2019, 02:08 PM
JonW's Avatar
JonW
JonW is offline
I have a 2014 Road King, and don't think my horn is all that loud.
Old 06-05-2019, 04:13 PM
ABQ-Jammer's Avatar
ABQ-Jammer
ABQ-Jammer is offline
Received 4,753 Likes on 2,317 Posts
Originally Posted by Hoginedgewood
https://www.northerntool.com/shop/to...SABEgIwlvD_BwE
i found a blemished Wolo bad boy and am very happy with it.
they have an all chrome model also.
Did that fit under your stock horn cover/cowbell?
Quick Reply: Loud Electric Horns, No Air Please
