Extended brake pedal
Does anyone know where to find an extended brake pedal for a 14 ultra. Kuryaken tells me that the 14 brake shaft is a different diameter than every other year, so they don’t have a listing for it. I figured that if anyone had an idea where or if available this would be the place to ask.....thanks
Go to a HD parts site to check/compare part numbers.
I am not sure who at Kury told you that. I have one on my 2014 Ultra and it works perfectly.
There was also a thread n here sometime ago (includes pictures)- here it is.
https://www.hdforums.com/forum/new-r...ake-pedal.html
MacDaddy - I have to agree with you. Did you read my comments used the link I posted?
__________________________________________________ _________________
I have the 9672 - don't believe the 8670 will work with the lowers.
Just as an FYI, the 9672 is moved forward a little. It does so by changing the angle. Imagine this.
Get a ruler - hold it against the desk at say 45 deg. Now, just change the angle to 33 deg. - see, it moved forward (same length but forward)
hbsoldier3 (04-16-2019)
