Advanblack fender extension or CVO fender with 18 SGS bags
Does your fender extension seem loose, king of rattles around?
They are CVO style bags. I think they are aftermarket. Got them from a member on here some time ago. Bought them because they were vivid black and already had the SGS pin stripe on it (aftermarket painted it) Once I got them installed, I noticed the pinstripe didn't line up with the SGS side covers I had swapped out. So this winter, I took off all the tins and in process of painting them Starlight black, with no pinstripe. Using ColorRite rattle cans and so far it is coming out nice.
Mine is Arlen Ness. I was just asking because when I first put it on, it was loose, it cracked in the corners. So I pulled it back off to repair and made a brace for underneath and attached it with JB weld. Then I noticed you have to loosen the rear inner fender brace and slip it (the part that slips under the fender) under that brace and tighten it up. Solid now.
Got my extension installed today, exhaust is 4.5” screamin eagle slip ons with no caps because the dealer never sent them. They’re swapping them for 4.5” MF hitmans once I get the time to run it back down tho. Paint looks to match well. My only bitch is the sides have a gap between the fender, left side is worse then the right side and the paint seems to scuff pretty easily.
