Dyno tuned 2014 flhtk
Tuned at Performance Choppers in El Cajon Ca. Mickey has 20+ years experience at tuning HD and if you want you can spend all the time you want in the Dyno room with him and he will explain the entire process to you, but be warned this is a 6-8 hour process.
For anyone thinking about needing a cam to gain more HP/TQ out of their bike, here is what is possible with a properly tuned (step tuned with a load controlled dyno) stage one bike;
Power Vision/Target Tune
Fuel Moto 2-1-2 jackpot header
Fuel Moto 4" jackpot dyno tuned muffler
Cold Air intake (S&S tear drop) externally vented
I'm extremely pleased with the results and if anyone in the San Diego area is looking for a good dyno tech Mickey at Performance choppers has over 20yrs experience tuning bikes and even builders in L.A. bring their bikes to him. I was a little apprehensive about getting a dyno tune and my bike was running pretty good with power vision and target tune, but I knew that I was also limited on what I could do tune wise, based on experience and knowledge your kind of limited to only dialing in your VE table and only in a limited area you frequently ride in. Be wary of tuners who say they can tune your bike in 3hrs or less for only $300.00, it can't be done. I'm glad I found Mickey.
The following 2 users liked this post by dcfatboy:
Beak (02-26-2019),
JayStronghawk (02-23-2019)
Here's a great thread on dyno correction factors:
https://www.hdforums.com/forum/the-d...smoothing.html
I find the difference in dyno tuning to be so different, (even if it's the same type of dyno tune, just a different shops) the regular guy like me wonders why people even hold it up as gospel. I have the same engine as the op but with a D&D Fatcat exhaust, Arlen Ness big sucker air intake, I forget the name of the tuner and a Andrew's 48H cam set. I was at 98hp and 110tq. So mine seems to be under performing the op's even though I have cam work done. Anyway, good numbers brother, better than mine and i think mine runs great.
Last edited by hbsoldier3; 02-22-2019 at 03:42 PM. Reason: Remove negative comment, my bad.
