2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Make my FLHTK similar to FLHTKL
Old 02-15-2019, 08:05 PM
RFG7680's Avatar
RFG7680
RFG7680 is offline
Received 1,280 Likes on 733 Posts
Changing the seat is one screw and the cost of the seat.
changing the bars is 3 to 6 hours of your time if you do it if not ask your dealer what they'll charge. You'll probably buy the seat
Old 02-15-2019, 08:10 PM
RFG7680's Avatar
RFG7680
RFG7680 is offline
Originally Posted by linerjoe
Here’s a picture of the seat on the bike. Any thoughts as to what seat it may be?
Just a quick Google search for the flhtk stock seat. It may be that you have the low. Looks a lot deeper that what I seen in the HD stock photos. My wife has a sundowner and hers has the crosshatch pattern. Dont know if they may a smooth sundowner.
Old 02-15-2019, 08:11 PM
Red's Avatar
Red
Red is offline
Maybe the H-D Tall which would be why you have to reach for the bars. Doesn't look anything like my Sundowner.
Go to the H-D.com store and compare to the Tall and other touring seats.
Take your stock seat to your dealer parts dept. They can tell you.
You've got a long time before you can ride. That's plenty of time to find a like new take off for $100-$150. Just have to figure out what you need or want.
Old 02-15-2019, 08:15 PM
RFG7680's Avatar
RFG7680
RFG7680 is offline
Think you nailed it with the Tallboy. Looks pretty damn close.
Old 02-15-2019, 08:31 PM
sleighcrane's Avatar
sleighcrane
sleighcrane is offline
Have you tried to just rotate your bars closer to you? I rotated mine upward and away from me and it made a nice difference. I just loosened the handlebar clamp adjusted and retightened.
Old 02-15-2019, 09:43 PM
ROCKOUT Rocker Products
ROCKOUT Rocker Products is offline
Sponsor
Received 1,635 Likes on 1,180 Posts
I have a '15 FLHTKL, with the stock seat. I Also have a stock FLHTK seat. Easiest way to tell them apart at a glance is the width.... about 15" on the low & 16" on the std. They even have different part numbers for the seat strap due to this.
BOTH have LOW stamped on the pan... means nothing.
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old 02-16-2019, 05:45 AM
Dsm Limited's Avatar
Dsm Limited
Dsm Limited is offline
Received 9,426 Likes on 3,217 Posts
The pictured seat almost looks like a Tallboy. If the passenger pad looks rounded(hard to tell in your pic), I'd say it is.
I would think looking at the Classifieds section here could net you a stock seat and bars from a FLHTK-L, for very reasonable prices. The downside to those bars, you lose the heated grips. Other differences on the low, the primary is thinner and the shocks are 1" lower as well.
Old 02-16-2019, 09:11 AM
linerjoe's Avatar
linerjoe
linerjoe is offline
Do you really lose the heated grips? From what I've read, the FLHTKL doesn't have heated grips because they are bigger diameter, so they went with regular non-heated grips. I think the bars are still 1" diameter, like the stock FLHTK bars, right?
And yes, I think this group is correct. It looks like a Tallboy seat. I'll take it to a dealer today, to try and verify. That seat apparently has the same height, but moves you back 1.5-2", which would certainly explain my issue reaching the bars, and liking the extra 2" pullback on the FLHTKL I rode.
joe
Old 02-16-2019, 11:34 AM
flstcbob's Avatar
flstcbob
flstcbob is offline
I have a stock seat from a 2014 FLHTK. If you would be interested in trading, send me a PM.
-Bob
Old 02-16-2019, 11:42 AM
Sponsor
Heated grips from the K will fit right up to the L bars... I've done it. If you want reduced diameter heated grips they are available in the P&A catalog, but I don't think they are internally wired.
Quick Reply: Make my FLHTK similar to FLHTKL
