V&H dual slash cut questions, 2015 SG
My 14 Ultra Limited can with V&H slash cut ovals, stock head pipes and stock intake. I recently went with Cobra power port head pipes and a V&H FP3. Also picked up a screamin eagle stage 1 a/c with a K&N filter from a member on here. After adding the cobra head pipes and the FP3, I could tell a nice difference in the way the bike runs. Before the bike would decel pop about three times around 1200-1300 rpm, still does it with the FP3. Hoping it will take care of it as I get more miles. 22 degrees here in Illinois. As for the screamin eagle stage 1 intake, it was added a few days later. It has a different sound to it compared to my 03 ultra. My 14 sounds ticky, like an exhaust leak when you get on it hard. My 03 almost sounded like a 4 barrel. Maybe its just the difference between the 103 & 88 inch motors or the K&N filter??
I also adjusted the throttle sensitivity with the FP3, no more lag. Great improvement.
All in all, V&H slash cuts, FP3 tuner, you cant go wrong with them. Still undecided on my stage 1. Will have to wait for warmer weather and more miles. Any one else experience this?
I put the monster V & H Slip on Ovals on my 2016 SGS last year , this winter I bought the fp3 and will be buying the required breather and will have that done by spring , that much I know , I have the option to swap out the stock pips for stock pipes with the cat removed , I understand this helps to support the other things mentioned not to mention the sound , can I get a Ya or Na on this , thanks
I installed an 09 head pipe on mine, any time you can remove resistance from the exhaust is a good thing.
I put V&H Slash Cut Rounds on my 2015 Street Glide Special when it was brand new (2016). I also added a K&N filter to the stock air cleaner. The bike ran a little hot as they seem to from the factory, but the bike ran great. Then I installed a V&H FP3 Fuel Pak and selected the V&H Slash Cut Rounds when selecting my map options. The bike ran cooler with even better power and gas mileage. The only thing I did was adjust the map for a bit more throttle sensitivity. I ride mostly 2 up on the SGS with the GF and HD King Tour pack added. No complaints at 22k miles.
