Easiest way to remove this stick-on bling?
The PO had this stuff put onto the inner faring bits and pieces and I'm in the middle of a full repaint, wheels, and tires and this stuff needs to go. I'm thinking a blow dryer and pulling on it with plastic things and fingernails. I assume it's just double stick tape and hopefully I don't booger up the finish with Goo Gone or WD-40 to dissolve the adhesive from it once I have these off. I didn't want to paint the inner faring, but if this goes sideways while removing this crap, now's the time so I can get it redone at the paint shop while the rest of the bike is already there. Anybody ever pulled this stuff off? Probably not salvageable afterwards I presume, in case someone wanted these to use for their bike.........
Stick-on bling..........
1. A hair dryer or heat gun set on LOW, just to gently warm up the adhesive. LOW!!
2. Using either monofilament fishing line or dental floss, wrap the thread around something like the handles of two screwdrivers. I like dental floss. It's less likely to leave marks on the paint.
3. Get started at one corner, and then gently work the thread back and forth as you saw the adhesive or double stick tape away from the painted surface. Try to keep the tension so that any rubbing back and forth is against the back side of the pieces you want to remove, and not against the paint.
4. When it's all off, use Goo-Gone, (NOT Goof-Off), and remove any remaining residue.
MotoJockey (12-25-2018)
Funny twist to this situation, the reason I'm even painting this bike is because the PO boogered up the tank when he owned it attempting to remove the tank badges with maybe a flat bar? or something. Not sure, but he had a screamin' buzzard airbrushed on the sides like a bad cover up tattoo. Had he used this method, I'd probably just left the bike Charcoal Pearl for a really long time, but here I am, knee deep into this paint job project, lol.
After you removed the badge and to get rid of just the adhesive? Or did you use it to help in the removal process? I wish I was removing this off of a nice painted surface like my tank but I'm a little leary of the finish on the inner faring.........
It looks like that inner was painted at one time. That will make it easier to get the adhesive off. If they are not painted and they are the standard textured black it might be a B$%^$. I have 3M adhesive remover that works well for that. Goo gone works it just takes longer to dissolve the adhesive.
Thanks for the heads up, but luckily all the parts are at the painters getting prepped to shoot right now. With as much real estate as I'll have to clean up, a fresh bottle of Goo Gone is in order I think. I use WD-40 for small jobs like stickers and stuff.
