roadglide headlight choice
Daymakers are going to be better than the stock halogens, but our Road Glide TruBEAM headlamp is the brightest option. The last time I took the Road Glide out, it was lighting up everything in front and on either side of the road.
Here's a video of the headlamp in action:
__________________
Custom Dynamics® - EVERYTHING To Light Up Your Ride!®
15 Cypress Drive
Youngsville, NC 27596
sales@customdynamics.com
https://www.customdynamics.com
http://blog.customdynamics.com
Review Custom Dynamics
Phone: 800-382-1388
15 Cypress Drive
Phone: 800-382-1388
dcfatboy (11-06-2018)
The only option I am aware of at this time is the new Custom Dynamics LED:
https://www.customdynamics.com/trubeam-road-glide?cat=2
That said, if you feel the stock Road Glide headlight isn't as bright as it should be, adjust it upwards a little. Most come from the factory focused a little low.
The following 2 users liked this post by steelerdude1:
davidwideglide06 (04-30-2024),
Wildon883R (11-11-2018)
I second this opinion. The stock LEDs are as bright as you'll ever need them to be. I also had to adjust mine up a bit, as they were low.
on my 16 i adjusted the lights, and adjusted the lights, then i adjusted them some more. Had a real hard time swallowing the price for the CD's.....wife said do it. I would do it again in a heart beat. Yes they are pricy. I talked to them to see if the pro-beams were in the works and they said not that they knew. So I got the true beams. Those things are brights and they give a lot more road side light then stock for sure. Still hard to swallow the price but not unhappy i did it either. I go to work at 4 a.m. and deer are a major factor so i wanted more light on the side of the road. They give it to me for sure. Brights are a tunnel of light in front of me and the lows stay on with the brights. The halloe's are pretty nice too. I would say 60% or more light then stock.
Also the above video from CD does not do it justice. it actually lights up more of the sides then it appears on the video. I think i have mine adjusted a little higher then his in the video.
On a motorcycle the only way to properly adjust headlights is with a rider sitting on the bike. Suspension load angle is definitely affected by rider/passenger weight.
