Regular push rods or adjustable
Depends on the cams that you are installing, not all cams have the same base circle, for example a Woods TW777 cam has a smaller base circle than stock Harley or SE Cams, if you have had heads milled down and running a thin head gasket then you have made the stock pushrod to long and unusable, there are many more reasons to use adjustable pushrods but this is just a couple. It's not really an advantage but a necessity in some cases.
Most people use adjustables so they can install cams without pulling the gas tank and the rocker box covers. They will cut the OEM pushrods with a bolt cutter, and then install the adjustable push rods after putting in the new cam.
Many people use them, many people swear by them, and many, many people have used them with no issues... me, I don't like adjustable pushrods.... just a thing of mine.
If I can't reuse the OEM pushrods (new cams with same base circle as OEM) I have a pushrod measuring tool. I will measure the zero lash, decide what preload I want, and then order custom size pushrods from Smith Brothers. I've done it for two of my bikes, it's a little extra work, but it works for me.....
If I was working in a shop, it might take too long for fast turnover, and I'd probably cave and have to use adjustables......
Another thing to consider, if you install adjs and want to replace lifters as many of us believe they are a wear item, it will be much easier with adj's..
S&S "Quickie" adjustables and their premium lifters with shims installed and the rods adjusted "long" - 1/4 turn "off the shim" - silenced the very-mechanically-noisy motor on my '15 Limited.
That's what I bought and installed 'em for and I couldn't be happier with the results. No clattering at start-up and no ticking - ever!
Also installed a set of Rockout rocker shaft shims, FWIW. Mine didn't have the rotating rocker-shaft noises at the time, and now it never will.
Absolutely lovin' my (mechanically) super-quiet motor now.
ROCKOUT Rocker Products (10-07-2018)
