Need Advice - Steering Head Bearing Lubrication
I'd like some input on steering head bearing lubrication. The Service Manual says to inspect and lubricate the steering head bearings at 25,000 miles. I am at 31,000 milesand will have new tires installed this winter. I very likely will have the handlebars replaced as well although I may do it myself. Have you guys found it necessary to do the steering head bearing inspect/ lubrication at around 25K?? If so I'll do it with the tire change. If not I'll be looking at doing it around 47K to 50K miles. Thanks.
What year bike , some had grease fittings newer ones don't. I have put 75,000 miles on an 07 and and never serviced the bearing other than 1 adjustment. But you read on the net of some that seem to being changing the every time you turn around. Ride until you notice any issue and if you do have it do right away. I have to this day never had a neck bearing fail.
Because I put a trike front end on my 2017 RGU it was all a part at 13,500 miles. The bearings and races were like new. I have them sealed up along with the other parts. My general rule is if something is being take apart for any reason , replace wear parts while you have it apart.
nocoast (04-05-2020)
No plans to "F" with 'em on either of my current bikes.
IMO, the only reason the MoCo recommends it is to help their dealerships rip off their customers by doing completely unnecessary and expensive "maintenance" at their ridiculously high (for what you actually get for your money) shop rates.
Kingglide549 (09-29-2018)
Thanks guys for the feedback. I've seen a lot of discussion on wheel bearings but dont recall much on the steering head. I live in a smaller city with only the HD dealer and one small Indy, who I haven't used. The dealer's track record is mixed, which I assume reflects personnel changes. The roads I usually ride are in fairly good shape so not too much pounding on the bearings, but I did ride it to Alaska 3 years ago. They lay on lots of crap on the roads to keep dust down. Probably will get it done sincebthey will have the wheel off already for the tires. Again, thnx for the input. I don't ride with any other Harley riders so the forum is very helpful.
These tapered roller bearings require little service from what I have seen.
Guess it depends on the road conditions and how hard you drive
I try to miss manhole covers and such.
Mine said to disassemble and inspect at 30K.
What a waste. They looked brand new.
All kinds of bad info out there on how to service and such. No telling what has gone on with yours.
Do what and how the service manual says
Then you will know.
Totally waste of time to listen to anyone who does not do his own work.
Then you will know.
Received 49,927 Likes
