ABS issues after 21in front wheel install
I installed a 21in Reinforcer rim last weekend after putting a few hundred miles on my ABS light continues to come on as soon as I get bike to speed. I went with a Dunlop 130/60/21 thinking I wouldn't have any ABS issues. My rear is stock with a Michelin 180/65/16 has anyone else had this issue with this combination? I've read most if not all the threads that come up in search and it seems this combination should work. I've verified the wheel rotating in the correct direction and that the bearing was installed correctly etc.
Thanks
Thanks
You're not supposed to have any issues with the 2014-later bikes when using the 130/60-21 Tire ... but it seems some still do
It seems the cheapest "Fix" is to use the Special ABS wheel bearing for those applications
Arlen Ness is one source for those bearings
http://www.arlenness.com/prodcat/ABSBearings.asp
Sputter (08-12-2018)
Sounds to me like you need a diameter specific wheel bearing. Same thing happened to me when l installed a 21" front wheel. Ness has the correct bearing and it solved my issue.
http://www.arlenness.com/prodcat/absbearings.asp
