2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Rear end noise
Old 08-04-2018 | 09:48 PM
rog246's Avatar
rog246
Default Rear end noise
I have a 2016 SGS with 6200 miles on it, went up to Lake Tahoe for the weekend where I picked up an unusual noise...Every time I wouldn't around a curve no matter which way I'd get a howling sound, stopped several times and looked for a loose rear wheel ie.(wheel bearings) but found nothing. Got home took saddle bags off and still couldn't find anything..any ideas?
Old 08-04-2018 | 10:37 PM
rsking45's Avatar
rsking45
I’d say you have a bearing or bearings going bad. I’d get the rear wheel off the ground and spin it and see if it feels rough or any side to side play or could be just the tire itself
Old 08-04-2018 | 11:00 PM
NORTY FLATZ's Avatar
NORTY FLATZ
Worn tires have been known to "howl" when leaned over onto the area that is "squared off."
Or, it could be substandard bearings...
Check your belt tension. If it's loose, it's bearings. If it's overly taught, it's bearings too.
mmesa005's Avatar
mmesa005
Also, check your belt for proper tension and overall condition.
Old 08-05-2018 | 02:52 AM
Mertoid's Avatar
Mertoid
Sounds exactly like tire cupping, you probably can feel a buzzy kind of vibration as you're leaning also.
Old 08-05-2018 | 06:31 AM
EasternSP's Avatar
EasternSP
Veteran: Marine Corp
Could have been the road surface.
Old 08-05-2018 | 07:24 AM
tpcowfish's Avatar
tpcowfish
My guess would be that the tires are at the point where they make the noise in corner s, my tires did the same with the oems,
Old 08-05-2018 | 07:26 AM
Harttoo's Avatar
Harttoo
Dunlop tires cup fast.Check Your tires for cupping.My rear tire noticeably howled at 8000 miles.
Old 08-05-2018 | 07:32 AM
bigrobtemp's Avatar
bigrobtemp
Tires. Mine has been doing it since new and bearings are fine. THey howl cause we are not using the lean angle as much and when we do they are not worn in that area.
Old 08-05-2018 | 08:58 AM
Rotor5's Avatar
Rotor5
I agree. Cupping on tires, probably front tire. This problem is not unique to Harley as well. You might hear it on some turns and not others.
Rotor
Quick Reply: Rear end noise
