Front Brake Does Not Disengage the Cruise Cont
014 SGS ..... Just recently noticed this. I did search but didn't see the same issue - Cruise works, brake lights work w/ Brake Lever engagement, can disengage the Cruise by rolling back the throttle or using the Rear Brake but the Front Brake engagement doesn't disengage the Cruise. I looked inside the hand controls but can't tell that anything looks bad or a loose connection.
Figured I'd ask here before digging into Elect Diagnostics which I'm not good at or a Dealer visit which I don't want to do, but may have to.
All Comments / Suggestions appreciated.
Campy Roadie (06-30-2018)
The brake light switch for the front brake is what also disengages the cruise. The lever keeps the switch depressed (brake light off) until it is squeezed, then the small tab moves and the switch is released (brake light comes on). I had this issue and it was intermittent. Most of the time everything would work right but then sometimes it would not. If applying the front brake doesn’t disengage the cruise, it doesn’t light up the brake light - huge safety issue. I temporarily fixed the problem on a trip by applying some wd-40 to the switch because it was sticking (not releasing fully). The real fix is to replace the entire switch pack. I ended up upgrading to the lighted ones because they weren’t much more expensive than the plain replacements. The lighted ones are $250 msrp but around 200 online several places.
As I said, the Brake Lights do work w/ the Lever & I haven't changed anything, it's stock. Took it out today & tested it again. I did get the Cruise to disengage but I had to almost lock the front wheel up to do it, way past the point of the Brake engagement & lights. So, I guess something is either out of adjustment, worn or something else. Ill keep digging. ..... Thanks
Uncle Larry (06-30-2018)
A couple months ago I had the same problem with my 2015 Ultra right after I got caught in a dust storm. By the next day it had corrected itself, telling me the switch got coated/dirty. Through more use the switch will clean itself up. If everything else in the right switch pack works I wouldn't rush into a new one. Meantime be ready to disengage cruise by other means.
