2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
ABS vs Non-ABS Pros and Cons
Old 06-25-2018, 04:10 PM
Cardstang's Avatar
Cardstang
Cardstang is offline
Default ABS vs Non-ABS Pros and Cons
Why should I or shouldn’t I get a bike with ABS?
Looking at a 2016 RG without ABS.
Old 06-25-2018, 04:20 PM
Sam2010's Avatar
Sam2010
Sam2010 is offline
I can't even think of a witty way to put this but it's a no-brainer go for the ABS.
Old 06-25-2018, 04:25 PM
show-n-go's Avatar
show-n-go
show-n-go is offline
After having ABS I am not sure I would want to ride without it. Seems silly after riding all these years without it but the bike stops so much easier with it.
Old 06-25-2018, 04:28 PM
Cosmic Razorback's Avatar
Cosmic Razorback
Cosmic Razorback is offline
Received 18,044 Likes on 7,313 Posts
If you are a talented rider, skilled, totally alert and always lucky it does not matter.
For those of us that appreciate the technical advances that have spilled over into bikes like ABS and Linked Braking it is a no brainer.
I have never had to reply on it on my last two bikes. But back with our 2010 Ultra it saved my neck twice. Once on ice that had frozen on the roadway from a sprinkler system spraying too far at a business, and once in rain having to get stopped fast for a quick red light. Once you experience it you go WOW thank God I had that.
Old 06-25-2018, 04:30 PM
wardo5757's Avatar
wardo5757
wardo5757 is offline
Well, the way I see it, a large cause of accidents on bikes is the rider grabbing a **** load of front brake in a panic, ABS eliminates that risk. I won't ride without it anymore.
Old 06-25-2018, 04:37 PM
shorelasHD's Avatar
shorelasHD
shorelasHD is offline
Received 2,858 Likes on 1,270 Posts
I find it hard to believe that the MoCo doesn't include it as standard equipment. Go figure.
The following 2 users liked this post by shorelasHD:
Bafflingbs (06-26-2018), zoozoo (07-08-2018)
Old 06-25-2018, 04:42 PM
2wheelwanderer's Avatar
2wheelwanderer
2wheelwanderer is offline
Thumbs up
^^This. I always put aggressive pads on my bikes. If I need to panic stop, I want it to PANIC stop. I've locked up the front tire on my bikes more than once. Every time I've also let out enough to get her going again without loosing it. I'm no pro rider by any measure, but I've never had the front wash out on me on the street. That being said, if I have the option, I'll always go for ABS. Its saved my bacon more than once, especially on wet roads or curves with marbles. ABS is a wonderful thing.
Old 06-25-2018, 04:59 PM
lyork's Avatar
lyork
lyork is offline
I wasn’t so sure about ABS when I got it. 39 years on the street, 23 different motorcycles...yeah, I’m good without ABS right?
No! ABS and the linked brakes are spectacular. I had a small “panic stop” and the bike stopped in about 1/2 the distance I was thinking it would! Get it, and you’ll be a believer when “that day” comes around.
The following 2 users liked this post by lyork:
Bafflingbs (06-26-2018), Yamaharley (06-26-2018)
nsdhoward45's Avatar
nsdhoward45
nsdhoward45 is offline
do you have ABS on your car - truck ? talk about a NO brainier , Duhhhhhh
Old 06-25-2018, 05:12 PM
RollaMo's Avatar
RollaMo
RollaMo is offline
It depends on the model.
Quite a few of them, it is standard equipment.
In the OP's case, it is an option on the regular Road Glide.
But it is standard equipment on the Road Glide Special.
ABS does raise the cost of the bike, so that is why they have models without it.
There are those that just don't need/want some of those extra cost options.
Quick Reply: ABS vs Non-ABS Pros and Cons
