2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Highway Pegs for New Limited
Old 05-31-2018, 04:25 PM
AFSOC_Commando's Avatar
AFSOC_Commando
AFSOC_Commando is offline
Originally Posted by Dr. Tiki
and how much lean angle do these things take away? I know they are mounted near the front of the floor board, but I can't see the brackets underneath well enough to determine.
I have the Ciro 3D highway peg mount on my FLHTKL so I am already lower. I have drug my heels on a few long sweepers slightly but they are in the perfect place for my short *** legs. On a standard bike like yours I think that if they were to hit you would already be over your maximum lean angle or the limitation of your tire adhesion.
I also think they look nicer then the standard mounts most folks use. I also use them 2 ways using them as highway pegs and then occasionally for a change of foot placement I will leave my heels on the floorboards and then the ball of my foot on the highway pegs.
They are heavy duty and well made.
Ciro3d (06-01-2018)
Old 05-31-2018, 07:10 PM
hillcountryflt's Avatar
hillcountryflt
hillcountryflt is offline
Originally Posted by Rob175
I went with the LONG angled ones on my 15' Ultra Limited. With my 30" inseam the long's fit me better and allow me to either place my feet on the pegs or just rest my heels on the floorboards while my shoe's toes rest on the pegs. That gives me lots of foot movement and position changes.
I just purchased and installed a set of the long angled Harley mounts with the simple long straight rubber pegs. Basically, pulled them in as far as reasonable and mounted them about an inch higher than rear brake pedal. With my 29 inch inseam, that seems pretty good. Have about 1k of miles before me starting Saturday and ending Monday. Will see if they are any more comfortable.
Old 06-05-2018, 09:17 PM
BgDadddy's Avatar
BgDadddy
BgDadddy is offline
Installed them today.
Old 06-06-2018, 06:22 AM
rwven's Avatar
rwven
rwven is offline
I've got the Harley ones also but mine have the longer arms. I had the dealer install them when I purchased the bike and I didn't specify which arm length I wanted. The short ones would have been fine as I've got the arms adjusted near vertical anyway..
Old 06-06-2018, 03:51 PM
flhchaz's Avatar
flhchaz
flhchaz is offline
Received 1,357 Likes on 513 Posts
Originally Posted by Plow64
Normally not a huge fan of Kuryakyn, but they got two things right: Iso Grips and these Offset Highway pegs. Absolutely love these pegs on my '15 Ultra Ltd.. They can be adjusted forward to give more leg room, or pulled back closer to the rider for shorter legs. Also can be adjusted higher or lower to the ground. Perfect fit for the lowers. Real solid and well constructed. Do a good online search for the best price, as prices vary quite a bit.
https://www.ebay.com/itm/Kuryakyn-Offset-Highway-Pegs-for-1-1-4-Engine-Guards-Tubing-7993/162556429946?epid=171260092&hash=item25d91e467a:g: ww4AAOSwMEtaYTIP
I agree with this! I have the offset pegs on my Limited and the ISO grips on my EVO. If my Limited did not have heated grips, I would have ISO grips on it as well.
Old 06-07-2018, 02:09 PM
115th FLHXS's Avatar
115th FLHXS
115th FLHXS is offline
I just bought a set of the Kuryakyn premium mini floorboards. They are black powder coated to match my black highway bar. It doesn't seem like there's anyway that if I tighten them down to get the clamp fully closed that it's not going to deform the highway bar. They just don't seem big enough.
Anyone run into this issue?
Old 06-08-2018, 07:23 AM
gigihurt's Avatar
gigihurt
gigihurt is offline
I thought the same thing when I put mine on. If they are for 11/4 bars they will work without deformation just seems tight.
Old 06-08-2018, 11:14 AM
115th FLHXS
OK - thanks!
Old 06-09-2018, 06:22 AM
Plow64's Avatar
Plow64
Plow64 is offline
If Kury ever comes up with heated ISO grips for the Ultra Ltd, I'll be all over it...
Gliden
04-23-2016 05:00 PM
RogFel
27
04-03-2015 06:59 PM
desertwolf
07-24-2013 05:16 PM
Doc R.K.
07-16-2013 10:03 PM
road_king_rob
07-14-2010 10:19 AM
Quick Reply: Highway Pegs for New Limited
