Ethanol free gas
Haven't seen 87 ethanol free in our area... 91 ethanol free is and has become quite prevalent as compared to 93 or 94 octane with ethanol. My first choice is the 91 free, 2nd is 93+ with ethanol. I would only use 87...if and only if nothing else was available and then only enough to get me to another station to get the better fuel.
Engines are now designed to perform perfectly fine using fuel blended with Ethanol. Much of the issues dealt with the effects of Ethanol on the plastics, rubber componds and other non-metalic parts and for the most part those problems occured early on in use of Ethanol. Here in the midwest, where the farmers grow much of this country's corn, Ethanol has been in fuel for 2 to 3 decades and all is fine. IF I had the choice between a 91 octaine "non-Ethanol" fuel and a 91 octaine Ethanol "blended" fuel I would choose the "non-ethanol" fuel. However, in this part of the country that choice isn't available but all of my machines run just fine.
I'd use the correct octane rated gas if it was me. I've used Premium with 10% ethanol, and do try to fill with non ethanol Premium when I can, but the bike runs fine on either one. In theory, ethanol free gas should result in slightly more mpg's, than the 10% stuff, but it'd be a pretty small difference, and I don't really track my mileage anyway.
I've heard others say that they have not problems running lower octane gas, but I stick to the octane rating the manual calls for, since they probably know more about it than I do.
