2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Replacing Primary Cover screws
Old 04-19-2018, 07:48 AM
nevets61's Avatar
nevets61
nevets61 is offline
In my humble opinion allens will strip before a torx will. Like nomadmax stated, the right bit (T27), antiseize, and torque is the cure all. Put a T25 in one and it'll strip if torqued too tight.
The following 2 users liked this post by nevets61:
Campy Roadie (04-19-2018), M Oclaf (07-02-2022)
Old 04-19-2018, 11:08 AM
GOV5's Avatar
GOV5
GOV5 is offline
Received 1,455 Likes on 933 Posts
It's not the "going in" that concerns me. It's the "coming out".
Old 04-19-2018, 11:56 AM
Brewmany's Avatar
Brewmany
Brewmany is offline
I've stayed with the factory Torx fasteners and have had no trouble with them. I use the correct (INCH POUNDS) torque, and do not use locktite (or anti seize for that matter).
I can see where using the wrong size (T25) might confuse a few since many torx bit sets don't include a T27. Less clear on what the confusion is on torque- are some people confusing foot pounds with inch pounds? If so, ouch....................
The following 2 users liked this post by Brewmany:
Idahokid (05-02-2018), M Oclaf (07-02-2022)
Old 04-19-2018, 12:48 PM
Sparkee...'s Avatar
Sparkee...
Sparkee... is offline
I use a torque wrench and blue thread locker, haven't had an issue yet.
Old 04-19-2018, 10:18 PM
Gwaxley's Avatar
Gwaxley
Gwaxley is offline
Originally Posted by GOV5
I was thinking about chaNGING the screws/bolts on the Derby cover from Torx to Allen/Hex. I'm tired of stripping those heads on the Torx because a tech power tightened them! At one time I had the dimensions of the bolts but I have lost that info. Does anybody know the correct dimensions of the bolt?
Also, would you go stainless steel or chrome?
Lastly, where do you go to buy them?
1/4-20 X 5/8 u can find SS bolts at most any hard wear store
Old 04-20-2018, 07:34 AM
dh_meyer's Avatar
dh_meyer
dh_meyer is offline
Originally Posted by dh_meyer
I dont recall where I got them way back, but will check to see if I kept any packaging/receipt/etc.
Found the packaging ...............
I bought mine from Colony.
And as others have said, 1/4 - 20 5/8" long (for my '99 RK)
Old 04-26-2018, 01:07 PM
smallwoodcd's Avatar
smallwoodcd
smallwoodcd is offline
Albany County Fasteners....swapped 'em out for allen heads a long time ago...
Old 04-28-2018, 07:40 AM
68 XLCH's Avatar
68 XLCH
68 XLCH is offline
Changed them out with Chrome, cause i like chrome, use a quality T27, no loctite, no anti seize, just use the correct tool and snug them up.
I change all three oils at 3K, so the primary comes off, i just use a ratchet and pay attention when working with all of the fasteners on the bike.
Old 05-02-2018, 09:36 AM
Idahokid's Avatar
Idahokid
Idahokid is offline
I haven’t had a problem but I can see a couple slips and that’s it.I may switch to allens.And yes,Inch pounds.
Old 05-02-2018, 05:34 PM
Wildon883R's Avatar
Wildon883R
Wildon883R is offline
I just use a torque wrench and follow the manual and i have no issues at all with torx. I'm not a fan of hex or torx fasteners period.
Quick Reply: Replacing Primary Cover screws
