Dash lights on and off after bar replacement?
Mine does the same thing. What I have to do is pull the main radio fuse and the bike will start up and then put the radio fuse back in. This has been going on well over a year. My back sat at Harley for 4 weeks and they couldn't figure the problem. Their resolution was to put a toggle switch onto the main radio fuse so when it does it again, I hit the toggle switch and that will simulate pulling the fuse out. Im at my end with this and don't know what else to do myself.
Good luck brother.
bigrobtemp (04-05-2018)
OK good news. I went out today and it was the right grip control wires just pinched a little bit. I grabbed the wire coming out and the dash lit up, then moved it and they went out. I took apart, checked for damage, put on some electrical tape. Then i carefully buttoned everything back together and rode the bike. Everything worked as it should. Bike ran great. Now on to the grips, i have power to grips but they wont get warm or even heat at all. These are Harley grips, and wired with their plugs and right to the instructions. I am not good at electrical but will stay with it. Thanks for the help on the running problem.
I don't remember specifically, but when I changed my bars, I didn't get the pins in the right grip into the socket. In fact, the pins were bent and I had to carefully straighten them before they would go into the socket.
