valve stems
valve stems
My 2017 Limited was new in Sept of last year. I enjoyed it as much as possible (about 3000 miles) before it had to be prepped for the Canadian winter months.
I tend to be a bit **** about tire pressures considering both tire wear and general safety. I noticed this bike did not retain pressures well. The bike was delivered with fairly long and skinny valve stems. If they were disturbed at all, you could hear air seeping around the base. My Dealer was great with the complaint - they remounted the tires after installing a much shorter fatter valve stem and since then, tire pressures are rock stable.
I hope other owners of new '17's haven't had the same problem, but if you do, check your stems.
Cheers
Rick
Cheers
Rick
That is just plain strange!
Was this bike delivered to you direct from the factory?
Or were the wheels/tires worked on before you took delivery?
Just this past week, I installed new tires on my 2016 FLHTCU. As before, I used oem valve stems, obtained from the local HD dealer. Into stock wheels. Nice and tight. Never a hint of leak.
When the bike is due for new rubber I'll be going with these
https://www.kurveygirl.com/shop/prod...roducts_id=673
Some other members have posted good results with these stems.
It was a new motorcycle that had been in the dealer's showroom for about a month before I bought it. The dealer's maintenance boss said that they had not seen the problem before.
My wife's Road King still has the stock stems, and it's such a PITA! I have her stems ready to go in when we get her her tires replaced.
Angled stems should come stock on bikes... not an added accessory, as important as proper tire pressure is on bikes.
