Fuel Pump attachment threads on tank stripped
2003 Ultra Classic. Several years ago the fuel pump was serviced and when i went to pick up the bike, it was leaking fuel from the top of the tank. Two more trips to the service department and it finally stopped leaking. It started leaking again and i realized that several of the screws holding the plate to the top of the tank are stripped. Harley doesn't seem to have a solution for this issue. Any suggestions??
I would go back to the H/D dealer that did the work but it was several years ago and they would probably claim that I did it. There is a gasket there but they over-tightened the screws so much (to get it to stop leaking I'm guessing) that it bent the rim of the tank. I've managed to straighten that out as much as I can. I thought about drilling and tapping to a larger size, but the one time use replacement screws from Harley only come in the original size and have a self-sealing ring on them that compresses when tightened.
kyledeuce01
Exhaust System Topics
01-12-2011 10:28 AM
