Installing heated grips on a 17 RGS
What the hell? I purchased Airflow heated grips today and according to everything I have seen online it should be a plug and play install. Very simple since the bike is pre-wired.
The grips I bought don't look like anything I see in the videos from several people on YouTube. My left grip has a plug in the center of the grip as well as a giant wire with a fuse attached to it and bare wire ends that need to be spliced. From what I can see in the videos the left grip should have one wire with a plug on it that you fish to the stem and just plug in.
What the hell kit do I have? The part number is 56100523
https://mstore.harley-davidson.com/store/airflow-collection-heated-hand-grips
I bought that too. It's a simple install on that even though the directions are abysmal. It really has no bearing on issues with the grips.
I realized what the issue is. Only HD could figure out a way to make this absolutely ridiculously awful.
The entire $269 line of "nice" grips like the Airflow are not setup to be internally wired but the shitty stock black rubber heated grips are wired to be plug and play. This is not obvious, apparent and does not make sense. Why would the cheap grips be designed to be internally routed and the expensive ones require a tacky install?
Also realized that HD put the wrong gender connectors on the bike when they pre-wired it so no wires the grips come with will work without cutting off the connector and replacing it. Of course, this is a whacky connector you need a special crimper to install that probably won't even fit inside the cluster if you had it to do the crimp.
I have reached the end of Google and YouTube at this point and I really do not want to put the rubber grips back on.
Very disappointed in this whole thing.
You can switch to the CVO grips.... they wire internally.
And are about $600
My factory black heated grips don't look so bad after all.
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
And are about $600
__________________
NO, they DON'T all do that!
Also on amazon.com...
