Heated Gloves
These are older and no longer made but these are great for about four hours or so. I have heated grips now so I rarely use the heated gloves anymore as the heated grips are great. But before he heated grips I had these battery power heated gloves from Harley (Made by Gerbing I believe) and they did a good job of keeping my hands warm.
Heated Gloves
I'm happy with 1st. gear heated Gloves & vest, I have it wired from a pig tail from Battery, Temperature control mounted on handle bar, 2 *****, 1 for gloves 1 for vest, run **** about 6 O'clock highest I've run is about 8 O'clock that is with a Harley Jacket over vest around 40°, plus I have hand wind shields mounted.
I've seen heated jacket at the dealer that is water prof or water resistant I liked don't know if jacket would work with 1st. gear plugs?
I've got a pair of Firstgear heated gloves and a TourMaster heated vest. I don't do any extended cold weather riding, mostly just back and forth to work, so I bought based on price. Tourmaster's vest comes with a dual controller so when I did the math it was the best bargain. The Firstgear gloves were the least expensive leather heated gloves I was able to find at the time. Both items worked well the few times I've used them, which was a few late winter day rides. My wife has used them for a group ride I host the end of April every year. Last year the temps on that ride were in the high 90s.......
The temp. for my 1/2 hour commute to work this morning was 32F. The heated grips were all I needed to keep my hands comfortable and a heavy Carhartt hoodie under my 3/4 length textile jacket kept the back of my neck warm.
I used HD's electric gauntlet gloves in miserably cold weather on long rides... HD sells a set of glove liner gloves that you can wear inside of them (I think they are silk... like ski glove liners). That was the only electric stuff I had but I had a full face helmet (no fairing, etc.). I wasn't afraid to ride anywhere anytime except on snow/ice.
One thing I will say about HD heavier gloves... it is almost impossible to dependably use your fingers on the controls, gas pumps, etc.
I've been up and down the street on this.
I've tried the battery operated gloves. Three different brands and all three are BS. They warm up a little bit when I don't have my hand in them but cool off when I put them on.??????
The heat by wire gloves. Really good when temps are in the 50s, but below that, the heat drops off pretty quick. 40 degree weather, I might as well not be wearing gloves at all. I currently have a set of Gerbing gloves that plug into a controller with the dial on it.
The heated hand grips are out of the question. Just not going to screw around with the aftermarkets that last a few weeks. Been down that road too.
I would like to find a good set of wired gloves that actually provide warmth down into the 20 degree range.
