2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
The USB port to radio on my 2016 Road Glide Ultra.
Old 10-23-2017, 09:53 AM
1989FLHS's Avatar
1989FLHS
1989FLHS is offline
Default The USB port to radio on my 2016 Road Glide Ultra.
Still trying to figure out this ride, I own a 2016 Road Glide Ultra, the USB port in the right front compartment, will this play music from my phone??? I have a Note 8. I'm assuming I'll a adapter from the port to my phone, what do I ask for?? Thanks for the help. Feel free to email me at ff_heatseeker@hotmail.com
Old 10-23-2017, 10:28 AM
jammerx's Avatar
jammerx
jammerx is offline
Just add a device bluetooth thru the radio, but yes it will play from the cord also. I don't have a NOTE 8 but I can't see it being much different than any other smart phone.
Old 10-23-2017, 10:32 AM
justgeorge's Avatar
justgeorge
justgeorge is offline
My 2016 Roadglide ultra will not play the music through the cord from my phone, a Samsung Galaxy 7. It does play it through Bluetooth , but only 1000 songs will load. I solved the problem by buying a cheap memory stick plugged right into the USB port and then all 5000 songs will play.
Old 10-23-2017, 11:50 AM
Ssitruc's Avatar
Ssitruc
Ssitruc is offline
Received 1,032 Likes on 706 Posts
I plug my Iphone in through that usb and it charges my phone and I can play all the music on the phone on the stereo. But I just put it all on a usb stick, several thousand songs, and leave it plugged into the usb, and bluetooth my phone to the stereo (if I wanted to take a call). Either way (bluetooth or wired) will work for playing music though. On your stereos "home screen", go to "media" to find your music on your phone or usb stick. Also, when I first put the usb stick in with around 7500 songs, then turned bike's ignition switch to accessory and went to media on the Boom, it took it an hour and twenty minutes to stop saying "reading" on the top of the screen. I let it do it without interruption, because i believe, from what I have read, it is indexing the usb drive. It only does it again if I take the drive out for some reason and put it back in. Also my iPhone has just as much music on it, but I have never noticed it doing this "indexing".
Old 10-24-2017, 10:32 AM
Manninagh's Avatar
Manninagh
Manninagh is offline
The bog standard USB cable you use for charging and syncing your phone will plug in there.
Old 10-24-2017, 10:55 AM
IdahoHacker's Avatar
IdahoHacker
IdahoHacker is offline
Received 2,991 Likes on 1,693 Posts
The USB port will play music off of a USB thumb drive that you plug into the port.
Or, you can Bluetooth your phone directly to the Infotainment system, and then it will play music from the phone.
Old 10-25-2017, 02:52 AM
FLSTFI Dave's Avatar
FLSTFI Dave
FLSTFI Dave is offline
Received 5,989 Likes on 2,365 Posts
Well it charges my iPhone and it plays music from my iPhone using the usb in the right glove box.
Old 10-25-2017, 06:46 AM
RollaMo's Avatar
RollaMo
RollaMo is offline
Is there something different about the OP's phone?
As mentioned, the iPhone will play music when plugged in.
I keep my iPod plugged in that compartment all the time, with all my music on it.
Old 10-25-2017, 10:43 AM
DamifIknow's Avatar
DamifIknow
DamifIknow is offline
If I plug my galaxy 5 into usb I can only scan Song not Artist.
Old 10-25-2017, 12:55 PM
Hammz's Avatar
Hammz
Hammz is offline
Could it be the tag info for the songs on your S5 isn't complete or in correct format? IDK, just thinking aloud.
Quick Reply: The USB port to radio on my 2016 Road Glide Ultra.
