2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Front and Back LED signals
Old 10-08-2017, 08:42 PM
OldPhat's Avatar
OldPhat
OldPhat is offline
My Ringz & Fillerz are Installed on a 2014 Street Glide standard Bullet style the smaller turn signals.
John
Old 10-08-2017, 09:04 PM
snafu's Avatar
snafu
snafu is offline
Originally Posted by Mchad
Many of you are talking about fillerz, but custom dynamics site shows they only fit Road Kings, limiteds, ultras and cvo models. Are you putting them on regular Street/Road glides/specials?
I put the FillerZ on my '17 Road Glide Ultra.
Old 10-08-2017, 10:04 PM
Mchad's Avatar
Mchad
Mchad is offline
Received 3,538 Likes on 2,145 Posts
Yes, that is a model they are listed to fit. I asked about ppl who appear to be installing on models they are not listed to fit...
Old 10-08-2017, 10:08 PM
Mchad's Avatar
Mchad
Mchad is offline
John
How did you install fillerz? Can you show me a photo? My understanding is they fit in the saddlebag/fender struts, but that is covered by the rear fender fascia on the Rushmore Street and Road Glides/Specials.
Not understanding how it's done.
Thanks
mastergunnera8 (10-10-2017)
Old 10-09-2017, 01:10 AM
shore's Avatar
shore
shore is offline
I put the CD's in the front, they look great. I got 1156's for the rear and of course they where the wrong ones. Not sure how that got messed up.
My signals flash correctly timed but my display flashes quickly. Not sure about that.
Old 10-09-2017, 05:59 AM
Mchad's Avatar
Mchad
Mchad is offline
Did you follow the learning process in the instructions? Your BCM needs to learn the lower resistance of the LCD's.
Old 10-09-2017, 09:24 AM
shore's Avatar
shore
shore is offline
I did do the flashers 3 times but maybe not long enough.
Old 10-09-2017, 03:59 PM
Mchad's Avatar
Mchad
Mchad is offline
Definitely not enough. If I recall, the instructions I read said 3 minutes, not three times. Try longer. That should fix it.
Old 10-09-2017, 08:08 PM
snafu's Avatar
snafu
snafu is offline
Understood. I looked at fitment on the CD website as well as fitment for the HD equivalent and neither lists the RGS or SGS. I looked at the parts catalog that I purchased at the same time as the service manual and it indicates the same part number (90200499 Support, saddlebag) for all touring frames. I looked at your photo in another thread and couldn't determine how the facia (filler panel) was attached. If the support is the same for all frames, I would think the filler could be removed and you could the mount either the HD or CD lights.
Old 10-09-2017, 09:54 PM
Mchad's Avatar
Mchad
Mchad is offline
True, the facia could be removed I suppose, but then I lose the fender tip light. Don’t think I want to do that. I’m working on a solution for the plasma rods which I think will work for me. Just wanted to make sure I was understanding the fillerz correctly. Don’t think they are for me. The flatz however look like they’d fit nicely on the facia. Once I get the plasma’s installed i’ll decide if I want more.
Quick Reply: Front and Back LED signals
