2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Exhaust sound....
Old 10-01-2017, 10:29 PM
Liam H'White's Avatar
Liam H'White
Liam H'White is offline
Originally Posted by motoXjoe
Since you already got the slip-ons, you could easily drill out the Cat with a spade bit and extension. That will open up the head pipe for alot less money, and only takes 30 minutes.
Slip off the slip-ons, drill until cleaned out good (check w/flashlight) fire it up outdoors to blow out the little pieces and re-install the slip-ons. No adjustments necessary.
is it that easy with a spade bit???
Any instructions would be amazing mate... thankyou
Liam H'White
Since you already got the slip-ons, you could easily drill out the Cat with a spade bit and extension. That will open up the head pipe for alot less money, and only takes 30 minutes.<br /><br />Slip off the slip-ons, drill until cleaned out good (check w/flashlight) fire it up outdoors to blow out the little pieces and re-install the slip-ons. No adjustments necessary.
<br />is it that easy with a spade bit???<br /><br />Any instructions would be amazing mate... thankyou
Carl_S
11-22-2015 12:25 PM
Timpsonsoldier
42
03-09-2015 05:56 AM
cnnesseth
03-11-2014 06:40 PM
chinbagger
12-06-2009 07:45 AM
zadmat
02-09-2007 01:50 PM
Quick Reply: Exhaust sound....
