SG Handlebar Help
SG Handlebar Help
Hello...2014 SGS
I recently mounted a 17" wide super solo Mustang. The new seat height and 1.25" rider move back, helps with my deteriorating hips and knees. However now I feel like I really have to reach for the bars. Currently I have stock the handlebars lowered as far as possible so not to hit the Tank Dash, in order to maximize the pull back.
Thinking about new bars. Sitting on the seat, while the bike is on my jack. I feel like a 2" rise and a 1 or 2" increase in pull back might work. I would like to have the bars higher and also closer to me.( not looking for super high Ape Hangers ). Measuring the stockers as close as I can without pulling any trim, it appears that the OE bars have about an 7" rise?
Any suggestions on what bars might be a good choice, or how to determine what to buy? Also it seems to me that bars pulled back closer might be an advantage while doing dead slow u-turns, and reduce upper back tension.
Thanks!
Thanks!
Hello...2014 SGS
Thanks!
Thanks!
These are the bars that I went with, after 3 rotator cuff surgeries (2 on left, 1 on right shoulder) I have no more Shoulder/Back pain, these bars really made a BIG difference!
Khrome Werks Handlebar 1" 2+2 Nrw Fl part# 300519 Narrow sweeper bars 2in up plus 2in back. End Rise: 13.53in. Width: 31.77in. Center Width: 12in. Pullback: 7.64in.
Bodacious MC (09-19-2017)
Here's a pic of WO578's (10") on my 17 Ultra. After I found the right position, these are very comfortable and I don't have any issues with my hands going numb anymore. Another great thing about these is nothing else was needed to install them. If you have heated grips and or plan on adding them, the left side will need to be modified a little. Cut off 3/8" and bore out the inside diameter a little (I suspect this is the case for most non-OEM bars). I have 10" PY Bagger apes on my SG that measure more like 12", they are comfortable as well but my hands go numb quite often on long rides.
I have the same mustang seat on my '15 SGS (part # 79446). Before I got the seat, I had 10" LA Choppers Twin Peaks on my bike, which were great with the stock seat. Now with the Mustang Seat, the feel for me is great riding around the city, however; then came my first extended trip.
I took a 250 mile trip from GA to Destin, FL last week of August. The first thing I noticed is that the bars were a little too far to be comfortable for an extended trip. By the time I reached Destin, my shoulder blades had some soreness.
I could always adjust the bars to pull them a little closer, but I'm actually considering changing out the 10" to a 12" (as I've heard you don't need to extend the clutch/brake lines for 12" Twin Peaks). I think even with a little pull back (if needed), the bars will still be at a height that is desirable to me.
FYI - I'm 6' tall if that helps.
