2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
cruise control not working
Old 09-05-2017 | 07:28 PM
Ron Mangus's Avatar
Ron Mangus
Default cruise control not working
my cruise control quit working. I also have no gear indicator. Any ideas?
Old 09-05-2017 | 07:36 PM
steelerdude1's Avatar
steelerdude1
Left switchpack. I'll bet it won't start in gear either.
Mine went before I got it home when I bought it new.
Old 09-05-2017 | 07:40 PM
Scott14SG's Avatar
Scott14SG
Before you buy a new switch pack try shooting some WD40 or other lube on the little plunger for the clutch lever. I've had this happen a couple times from riding in hard rain for a while, it gets gunked up and sticks. If it's wet let it dry then lube it up.
Old 09-05-2017 | 08:07 PM
smitty901's Avatar
smitty901
Check N/ gear indicator switch also easy to pull it lube up the ball free it up put it back that often fixes them.
Old 09-05-2017 | 08:22 PM
tpcowfish's Avatar
tpcowfish
Probably left switch pack, does the odometer button work, on the left switch pack, that switches from the odometer, miles remaining ect? When mine went, that was one of the signs
Old 09-05-2017 | 08:27 PM
Ron Mangus's Avatar
Ron Mangus
thanks guys. I am on a road trip right now. when I get home I will try your recomendations. It did start happening after riding in the rain for 5 hours.
The gear indicator is linked to it somehow.
Yes, it won't start in gear now.
Old 09-05-2017 | 08:53 PM
steelerdude1
Yep, rain is what did mine in on day 1. Dealer said it's a known problem. Even if your out of warranty, I would fight for a new one since it's been an issue. It will probably work when it dries out for a while, but will eventually go.
If if it starts working again dump a ton of water on it before you take it in so they can't deny you if it comes back and works.
Old 09-05-2017 | 09:36 PM
cycle7447's Avatar
cycle7447
I think we will all agree it is the left switch pack. You didn't mention your bike year - but, since you joined in 2015, I might guess the bike is a 2015 and under warren.
If so, take it back to the dealer for a replacement- but ask for an "Upgrade" to the lighted switch pack. The lighted ones didn't seem to have that issue.
Should only be a few dollars more.
Old 09-06-2017 | 11:00 AM
Ron Mangus's Avatar
Ron Mangus
It is a 2015 Limited. Is the switch pack linked to the gear indicator. I think the gear indicator not working is the reason the cruise is not working. my odometer reset is working.
Old 09-06-2017 | 11:12 AM
BILLL1121's Avatar
BILLL1121
when you pull in the clutch you never see what gear your in. plunger is probably stuck in..
Quick Reply: cruise control not working
