It is a 2015 Limited. Is the switch pack linked to the gear indicator. I think the gear indicator not working is the reason the cruise is not working. my odometer reset is working.
The gear indicator, no start in gear and the cruise not working is all tale tale signs of a bad switch pack. You can try to mess with the plunger (I did too), but I don't think it's your issue.
If you remove the clutch lever, you can see where it pushes the plunger.
I would be willing to bet you could get the MOCO to replace the left switch pack. They have had to replace a ton of them including mine.
Update on switch pack.
Not wanting to spend 200 bucks for a new switch.
I removed the switch housing and sprayed a bunch of wd40 to the back and front of switch.
wiped all the excess off and Presto!! It is back to normal operation.
I hope it stays working, time will tell
Thanks to all for the suggestions!
