Having a tough time finding out how to change the am to the pm in the right field. Not the 12 hour to the 24 hour nor the clock setting in the left field.
The right field one can set with the arrival time, arrival distance, CLOCK etc. and when one selects Clock the RIGHT field does turn to the clock ON THE RIGHT SIDE, just am.
Best way I have found. Go to the clock, set it for 24 hours.
Move the hours to the correct time (so, if you are doing this at 6PM, the hour would read 1800). Once you have that set, then take it back to 12 hour clock.
[QUOTE=Just Me;16569862]I don't think it matters if it's am or pm don't believe it shows option. If it showed a date then it would make a difference .[/QUOTE
From the home screen press the Setup button. Then use the down arrows to find the Clock option and press it. Make sure the GPS Time is on, then you never have to adjust it.
Yes... When I was riding a route out west it threw me for a second when it changed time zones real time.
