2013 flth no oil pressure
16,k miles with no modifications or what so ever .i've replaced the oil pump and the cam plate ,all the prongs .assuming that was the problem , put them back together no bueno prior to this i just noticing that the oil gauge was only 5psi.on startup every now and then for about 2-3 munites.
oli and oil filter was new from HD. is there any checkvalve anywhere in this oiling system ?
and also check the crank runout is just .03 thanks
