Handle bar swap question
I went with Wild One WO578's which are more of a 10 inch bar and also wider than stock. I had no issues at all. As mentioned above it does depend on the bars as they are measured differently. On some 12 inch they will work with some re-routing of the cables and lines.
There are a lot of very good handle bar threads on here. Do a little searching.
I had 12.5" Wild1s - WO577s on my 2014 Ultra Limited and the brake and clutch cables only needed to be re-routed at the neck which was easy, but it needed the control wire extensions... 8 inch was fine.
So i recently installed the WO578's and my Namz wiring extensions where on back order. I was able to disconnect the right and left hand control wires from under the radio and pull back to the bars and had just enough room.
If i were to do it again i would have waited on the extensions.
If you decide not to go with the extension leave the wires connected until you pop them off under the radio. It will make it much easier pulling back to the bars.
