Legend Revo question
I started with the Revo's on my 14 SG and they just weren't doing it for me. I talked numerous times with Jason at legend(great guy and great customer service) and he ended up sending me a set of Revo-A's and I loved them. My problem was my weight or should I say lack of. I'm only like 165 and the adjustable rebound made them work for me. If you're a bit heavier I would say the standard Revo's would by fine for you. Defininely get the 13" though, you'll be glad you did. You'll actually be able to get some sag with these, I couldn't with the stock shocks. The salesman measured mine with the 13" Revo's and an SG with stock 12" shocks, mine was only 1/4" higher and he was measuring from the groung to the bottom of the rear fender. Hope this helps!!
Jim
Jim
Jim
Jim
IMHO the extra money for rebound adjustment is worth it and these Legend shocks do a great job. They are expensive, but the build quality is excellent.
I have the Revo A's on my 15 CVO Road Glide. The rebound adjustment is well worth it. I ride two up a lot of the time and adjust for the difference in weight. The adjustment just gives you the ultimate ride. Once you dial in the shocks themselves, its very easy to adjust the rebound for one or two up riding.
Call Legend Customer Service, I've dealt with them, they are very helpful.
Why do they make the Revo... IMO, Price point. Revo A's allows you to fine tune your suspension
Product Description - Revo
- Legend's touring specific spring rates produce superior ride quality and performance
- REVO coils provide improved plush ride quality, control, and resistance to bottoming-out
- REVO's extended coil length has larger "sweet spot" without increasing overall shock length
- REVO's unique spring rate offers the ability to soften pre-load, reducing ride height and maintaining a smooth ride
- Allows minimal pre-load adjustments when changing between riders' weights or loads
- Adjusts by hand, no tools needed
- Available in 12" and 13", standard or heavy-duty applications
- Easy installation and alignment, provided by spherical bearings on both top and bottom
- NOTE: Heavy Duty applications are recommended for 500lb. + rider and passenger total weight.
- Backed by Lifetime Warranty
- Made by hand in Sturgis, South Dakota, USA
- All the benefits of the new REVO shocks above plus six external **** adjustments allow fine-tuning of rebound
- Provides optimum rebound performance for any given rider weight, personal ride quality preference, or personal riding style
- Light to heavy riders can fine-tune ride preference
- Aggressive to casual riding styles can tune to desired quality or personal preference
