2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Road king special speedo/tach replacement
Old 08-17-2024, 04:07 PM
MYFOB's Avatar
MYFOB
MYFOB is offline
Stage III
Originally Posted by CheefASRC
I don't think inaccurately made my point i apologize. I meant to say is there a sort of gas gauge delete of sorts? Like a pop up gas cap, instead of having to buy the flush mount gauge kit while having the new speedo/tach unit with its integrated fuel gauge its wasted $.
I just want the blacked out flush mount look not two gas gauges. Thank you!
I used chromed with the chrome and silver dial on mine. My RK is Big Blue Pearl and Vivid Black so most lights are blue on it... and since the kit gas indicator are light blue lights... I kept mine active.
Old 08-18-2024, 12:18 AM
NorthWestern's Avatar
NorthWestern
NorthWestern is offline
Received 6,250 Likes on 3,410 Posts
The OP hasn't logged in for 7 years, he may not reply back.
Old 08-18-2024, 12:35 AM
MYFOB's Avatar
MYFOB
MYFOB is offline
Stage III
That's called working 20h/day for the past 3 days.
Thanks for the wake up call.
Finally 5 days off... hopefully.
Old 08-19-2024, 08:35 AM
JimRunningLizard's Avatar
JimRunningLizard
JimRunningLizard is offline
will do, I'm thinking maybe a cheaper black pop up gas cap from J&p or something, cut it down to the top and silicone it in?
The Mothership offers a kit I put on my 2020 Fat Boy ( #61100132) that has a blank (plastic) stick on for the left side of the tank. Not much of a cost savings at $129.95, nut every little bit helps.. We all know what HD stands for.
I've had it on the bike for a while and the blank disk is still on the left side.
Also, you may want to look at the left side disk and where the 3m sticky tape is and make sure it will be outside the left side gauge hole.
Good Luck
Old 08-30-2024, 04:23 AM
Big Al 59's Avatar
Big Al 59
Big Al 59 is offline
Just a question, can I mount speedo from an M8 Softail on an M8 Road king ?
phlacoe
06-04-2023 10:02 AM
LJL4
07-28-2017 07:43 AM
DynaNYC9
Electrical/Lighting/Alarm
06-26-2017 09:59 AM
polbit
04-24-2015 12:59 AM
JonGolden
06-03-2014 11:23 PM
Quick Reply: Road king special speedo/tach replacement
