Has anyone installed fairing mount aux power switch - 16 RGS
I was looking at getting one of the HD 71400105 aux power switch kit - which installs under one of of the blanks already on the panel by the ignition switch on my '16 RGS. Looking at the kit, it looks like all the wiring is in the fairing, but the instructions say to access the connector under the left side panel.
So I'm a bit confused and am wondering if anyone here had installed one themselves and could clarify.
Thanks
Thanks
Thanks
Thanks
Mchad (06-16-2017)
Reference to left side panel is because that's where the Accessories connector is located. Adding switch assembly to control added accessories uses the BCM to switch power to wires in the accessories connector. H-D has 3 different accessories wiring kit options:
- switch pack & controlled accessories wiring
- switches to plug into the switch pack & controlled accessories wiring
- hot, unswitched accessories wiring
Weaselbeak (04-24-2018)
So you can install the switch bank then plug directly into a harness and have AUX power without having to buy another UAX power harness kit?
Is this kit all thats needed?
https://www.harley-davidson.com/stor...05-71400129--1
